976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 01, 2026, 12:47 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuf neck power disk - Redline double pinch flight crank
Author Topic: Tuf neck power disk - Redline double pinch flight crank  (Read 1503 times)
Offline Sicura
« on: March 16, 2014, 08:44 PM »
Hi,
Does any one know if I will be able to easily fit a Tuff Neck power disk onto a Redline double pinch crank?
Thanks for your help!!
Offline Munnyella
Re: Tuf neck power disk - Redline double pinch flight crank
« Reply #1 on: March 16, 2014, 09:03 PM »
Yes, you'll need a top hat washer though, think its a 19-23.8mm, sure someone else will confirm.
I did it on my old floval.
MM
Offline Sicura
« Reply #2 on: March 16, 2014, 09:08 PM »
Thanks!!
Offline Sicura
« Reply #3 on: March 16, 2014, 09:12 PM »
Is fitting the power disk an easy job? Or is there anything I should know about?
Offline Munnyella
« Reply #4 on: March 16, 2014, 09:25 PM »
Nah, dead easy, if you do it wrong, it wont work, chain alignment is the trick, but you should have spacers in the bottom bracket kit to sort that.
MM
Offline Sicura
« Reply #5 on: March 16, 2014, 09:32 PM »
Unfortunately not,  the crank came on a frame I brought! Any idea where I can the spacers from? At the moment it does not line up, it sticks out to far!!
Offline Munnyella
« Reply #6 on: March 16, 2014, 09:35 PM »
get some pics up, so we can see where you are at.
MM
Offline Sicura
« Reply #7 on: March 16, 2014, 09:59 PM »
Hi,
This is how it is at the moment. I am waiting for the power disk to come through the post.
Thanks for your help on this!!
Offline southern andy
« Reply #8 on: March 17, 2014, 08:21 PM »
On the drive side, is there a spacer there in the shape of a cone ???? If so then it could be removed for it to line up better with the freewheel.
Offline Sicura
« Reply #9 on: March 17, 2014, 08:32 PM »
Hi,
Yes I think there is! It revolves when you turn the pedals.
Thanks
