976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 30, 2026, 01:13 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dyeing Wheels? Photo added
Author Topic: Dyeing Wheels? Photo added  (Read 8402 times)
Offline hokuspokus74
« on: April 16, 2014, 03:58 PM »
Am looking to dye a set of skyway oe's to white,what is the best dye and the best formula to use to get the white,as there like an of white/light cream.
Also have a blue set of Z-Rims and want them black what dye to use and formula for those etc
cheers graham :daumenhoch:
« Last Edit: April 19, 2014, 05:20 PM by hokuspokus74 »
Offline chubby
  • Needs Pegs
Re: Dyeing Wheels?
« Reply #1 on: April 16, 2014, 08:14 PM »
Dyeing the skyways wont make em whiter Graham, you'll need to bleach em bud. Industrial peroxide works but needs sunshine for best results. .
I find black rit the best black dye & normally whack 2 packs in & 1kg of salt fella. Never done zd's so don't know if they take well or not  :daumenhoch:
Offline chubby
  • Needs Pegs
Re: Dyeing Wheels?
« Reply #2 on: April 16, 2014, 08:18 PM »
www.radbmx.co.uk/forum/index.php/topic,164600.0.html
Have a wander through this for the skyways,  stuffs available on the bay.....
Loads of dying threads on here too mate  :D
Re: Dyeing Wheels?
« Reply #3 on: April 16, 2014, 08:40 PM »
Cheers chubby  :daumenhoch: went and bought a plastic box there in B&Q,a little to small for the rim  :-\ but i got a polystyrene box big enough so am going to line it with my pool table cover incase the poly would suck the dye in.
To bleach the skyways pure bleach or watered,and how long for?......have you tried it before?
Online oldschoolace
Re: Dyeing Wheels?
« Reply #4 on: April 16, 2014, 08:49 PM »
Graham if you are going the bleach route get the really cheap Tesco own brand bottles, I think they are 2 litres. Any thin stuff will do and don't forget to vasaline the hubs or the bleach will affect them.
I left mine in for 2 days then gave them a really good rinse and a good coating of wd40 while hanging on the washing line through the valve hole. Worked great :daumenhoch:
Online oldschoolace
Re: Dyeing Wheels?
« Reply #5 on: April 16, 2014, 08:53 PM »
Taken a few days after they were done
Re: Dyeing Wheels?
« Reply #6 on: April 16, 2014, 08:59 PM »
wowwwww excellnt job that what my oe's are for my decade build :daumenhoch: as for the rit dye is it powder form or solution...going to order it of ebay cant find anywhere that sells it
Offline chubby
  • Needs Pegs
Re: Dyeing Wheels?
« Reply #7 on: April 16, 2014, 09:21 PM »
Exactly what Clint says Graham  :LolLolLolLol:
Re: Dyeing Wheels?
« Reply #8 on: April 16, 2014, 09:55 PM »
hey chubby what is the dye you use rit solution or powder form?
Offline chubby
  • Needs Pegs
Re: Dyeing Wheels?
« Reply #9 on: April 16, 2014, 10:44 PM »
Packs of the powder Graham,  make sure it's dissolved well in your container though
Re: Dyeing Wheels?
« Reply #10 on: April 16, 2014, 11:01 PM »
ok will do,would you use warm water or cold from the hose pipe? god sounds stupid asking these questions i am such an :Aresehole:  :D
Offline chubby
  • Needs Pegs
Re: Dyeing Wheels?
« Reply #11 on: April 16, 2014, 11:46 PM »
Water needs to be as hot as you can get it, doesn't need to be boiling away but hotter the better mate
Offline laidback
Re: Dyeing Wheels?
« Reply #12 on: April 17, 2014, 12:28 AM »
Hi HokusPookus,
I have just bleached my OE's for my decade. They were awful before hand.  Before you try anything else, get a bottle of Cillit Bang with bleach, looks like this:
Spray the wheel, leave for 15 mins, scrub with a softish scouring pad and rinse.  Do this again a couple of times until it looks clean.
Just using the above method turned this:
Into this:
A comparison:
The result was so impressive, im debating whether to bother using peroxide on them.  Can they be 'too white' for a survivor? 8)
Offline laidback
Re: Dyeing Wheels?
« Reply #13 on: April 17, 2014, 12:32 AM »
OldschoolAce- Should i now WD40 my wheels? Why does that need to be done? i've read about it elsewhere...
Re: Dyeing Wheels?
« Reply #14 on: April 17, 2014, 12:48 AM »
wowwww laidback seriously it turned out like that,excellent job,got to try that tomorrow when i finish work :daumenhoch:
you got any other good rest tips & tricks :)
cheers
Offline chubby
  • Needs Pegs
Re: Dyeing Wheels?
« Reply #15 on: April 17, 2014, 03:48 AM »
No need to wd40 them bud, you've only cleaned them. People use the wd on wheels after dying as they come out dull/dry looking & need shinning up. You've had a great result with that cilit bang,  barry scott is a genius........... LolLolLolLol
sent using my crayons
Re: Dyeing Wheels?
« Reply #16 on: April 17, 2014, 06:56 AM »
For white Tuffs the best way is aquablasting. You will be amazed :shocked:
Sid1972 found a place in Barnsley called Metal Magic who do it and they come up amazing for about £25-30.
I got a set done for Animal and SteveVXR so ask them how good they came up :coolsmiley:
Re: Dyeing Wheels?
« Reply #17 on: April 17, 2014, 03:12 PM »
Yeah ive heard of aquablasting i was looking for someone over here to do it,think i will try laidback trick of doing and see how it goes for me. :daumenhoch:
Offline laidback
Re: Dyeing Wheels?
« Reply #18 on: April 17, 2014, 03:17 PM »
It's £3.50 a bottle. Gotta be worth a go! The photos make them look brighter white than they actually are, but I'm pleased with them! That cillit bang and a scourer even got rid of brake rub. :daumenhoch:
Re: Dyeing Wheels?
« Reply #19 on: April 17, 2014, 03:31 PM »
what type of scourer mate i take it isnt one of them green pads,just i know there is loads of scourers and id prob get one that would be rough on the wheels. :)
Re: Dyeing Wheels?
« Reply #20 on: April 17, 2014, 08:39 PM »
bloody tescos never had the cillit bang with the bleach,brought another cillit bang and see if that works ,if not will need to look else were to see if i can get that type of one :daumenhoch:
Offline laidback
Re: Dyeing Wheels?
« Reply #21 on: April 17, 2014, 08:43 PM »
I think it's the bleach ingredient that does the trick mate. I picked up another bottle today, as it was on offer ;D As for the scourer, i used a green one to get the brake rub off- the braking surface isnt scratched.  On the rest of the wheel, i used a well used scourer-one of the ones on the top of a sponge.
Re: Dyeing Wheels?
« Reply #22 on: April 17, 2014, 08:54 PM »
Top tip of the day  :4_17_5:
Re: Dyeing Wheels?
« Reply #23 on: April 17, 2014, 10:19 PM »
what supermarket you pick it up in i was up and down the cleaning isle like a blue arsed fly lol
Offline laidback
Re: Dyeing Wheels?
« Reply #24 on: April 17, 2014, 10:33 PM »
Tesco
