976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 28, 2026, 04:49 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Mongoose wheels
Author Topic: Mongoose wheels  (Read 3227 times)
Offline DT
Mongoose wheels
« on: June 07, 2014, 08:34 PM »
Hi everyone.
I am building a 1980s mongoose Cali and have got hold of a pair of what appear to be alloy rimmed wheels (the ones with the holes in) and suzue hubs. There is a pro class decal apparent around the valve which looks orig but not sure.
They appear to be in reasonable condition but need to be respoked as they are quite rusty.
Not sure what my options are here, are nos spokes available or is it best to go stainless?
And can anyone recommend either somewhere to get hold of the spokes and retainers and also if anyone is recommended to response the wheels?
Also need replacement rim tape, I presume it's a specific part ? Is it available?
Any help would be very much appreciated
Re: Mongoose wheels
« Reply #1 on: June 07, 2014, 08:41 PM »
Hi DT,
You've got yourself a pair of Pro Class rims, which will need a set of 194mm stainless Asahi spokes available from JTSmooth for a tenner or thereabouts. These will come with chrome nips.
The standard rim tape on these is black, if you want to fork out, there are KINK bike Co or other new school types available on eBay, they will probably have a logo printed on them, but you can turn them inside out.
Your local bike shop will lace them and true them for you, mine charge £18 per wheel.
Offline DT
Re: Mongoose wheels
« Reply #2 on: June 09, 2014, 07:32 PM »
Thanks retro dan, advice is very much appreciated :-)
Re: Mongoose wheels
« Reply #3 on: June 09, 2014, 07:34 PM »
Anytime fella, I forgot to add, for a cheap alternative to rim strips, use electrical tape.  :daumenhoch:
Offline EDBANGER
Re: Mongoose wheels
« Reply #4 on: June 09, 2014, 07:44 PM »
Rim tape is easily made using electrical tape back to back.  Cheap as chips and does the job just as well.
Offline DT
Re: Mongoose wheels
« Reply #5 on: June 09, 2014, 07:47 PM »
Thanks dan and ed.
Quick question, do I use a few layers as I'm conscious that the inner tubes will try to bulge out of the holes?
Re: Mongoose wheels
« Reply #6 on: June 09, 2014, 07:53 PM »
Thanks dan and ed.
Yes definitely, as many layers as poss.  :daumenhoch:
Offline DT
Re: Mongoose wheels
« Reply #7 on: June 09, 2014, 08:21 PM »
Ok Thankyou both for your input it's much appreciated.
I'm off to cut the spokes out! (Pics first just incase) :)
Re: Mongoose wheels
« Reply #8 on: June 09, 2014, 10:59 PM »
Don't tell anyone,  but this will do the job and check the other colours they do  :coolsmiley:
http://m.ebay.co.uk/itm/390035029942
Don't forget to take the freewheel off before thinking about stripping a wheel down - there is a "how to" sticky thread in the sresto section if you fancy a go yourself :daumenhoch:
Offline Rabdul06
Re: Mongoose wheels
« Reply #9 on: June 10, 2014, 01:57 PM »
   NNNNNNNoooooooooooooooooooooooooooooooo don't cut the spokes out...!!!!
   Just take ten minutes to unscrew the nips and remove the spokes. You can get them up good again using 0000 grade wire wool.
   Clean it all up ad then re-lace using Caleb21 guide over on the museum. Take to LBS to true up. Job done and another set of OS wheels saved..... :)
   Ive done a couple of sets of 7X/Proclass like this and they look ace.....
Offline maca
Re: Mongoose wheels
« Reply #10 on: June 10, 2014, 10:09 PM »
I used this on mine, not as cheap as other options but its bloody good.
http://www.ebay.co.uk/itm/120779965396'ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Offline AL_B
Re: Mongoose wheels
« Reply #11 on: September 13, 2014, 09:27 PM »
Hi
I'm restoring my 81/82 Mongoose and it's Pro Class wheels. I'm missing 2 spokes from the front wheel and 4 also need replacing because they are bent.
Do the Asahi spokes have the long brass nipples?
Here are some pics of a pro-class spoke:
Nipples are 16mm.
I bought 6 individual stainless steel Halo spokes, but the thread on the spokes is a little bit shorter, the nipple is 12mm and the nipples are silver not brass.
Can anyone give me some advice? Please don't say re-spoke, as I want to keep this bike as original as possible, as it's a survivor and my BITD bike.
AL
« Last Edit: September 13, 2014, 09:54 PM by AL_B »
Offline hokuspokus74
Re: Mongoose wheels
« Reply #12 on: September 13, 2014, 09:42 PM »
I used strips of material on all my pro-class rims does the job :D :daumenhoch:
Offline AL_B
Re: Mongoose wheels
« Reply #13 on: September 15, 2014, 03:29 PM »
Has anyone got any advise regarding my post about spokes?
Alan
Re: Mongoose wheels
« Reply #14 on: September 15, 2014, 11:15 PM »
Alan can you not just use the new spome with the original nipple? Turn it with a spoke key if the screwdriver slot on the back has sheared as most of them do when they tighten them in a factory originally, but it's still perfectly safe to use :daumenhoch:
Offline AL_B
Re: Mongoose wheels
« Reply #15 on: September 15, 2014, 11:36 PM »
Thanks Spen69
That's what I did in the end. The HALO (195mm) spokes are a perfect match. There are only 2 spokes where I have had to use the shorter nipple and it looks ok.
The restoration is coming along nicely.
