976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 29, 2026, 08:58 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  1/2" axle sealed bearing pedals???
Author Topic: 1/2" axle sealed bearing pedals???  (Read 2078 times)
« on: July 08, 2014, 04:15 PM »
Need some modern 1/2 inch sealed bearing pedals for a little project, whats out there going cheap guys? All the wellgo type pedals i can find on the bay dont specify the bearing type  :(
Re: 1/2" axle sealed bearing pedals???
« Reply #1 on: July 08, 2014, 09:39 PM »
Any ideas gents?
Offline chubby
  • Needs Pegs
« Reply #2 on: July 08, 2014, 10:16 PM »
You just want to use the spindles & bearings from em clint ???
Offline chubby
  • Needs Pegs
« Reply #3 on: July 08, 2014, 10:21 PM »
Are plastic peds more likely to use sealed bearings ???
« Reply #4 on: July 08, 2014, 10:34 PM »
I need the lot Richard, need to take some accurate measurements for the bearing rebates etc. All the modern stuff seems to be 9/16 or loose ball when it's 1/2  :(
Offline Gary72
« Reply #5 on: July 08, 2014, 10:52 PM »
Not sure on the fesability, but could you not just re-thread the 9/16 down to 1/2?
« Reply #6 on: July 08, 2014, 11:12 PM »
I thought of that but trying to avoid it if possible  :-\
Offline Dannywhac
  • return of the whac
« Reply #7 on: July 09, 2014, 08:58 AM »
I think you're stuffed on modern one's Clint - maybe ask over at Flatland Fuel as those hoppity little bunnies regularily use 1-piece cranks fella and might know of a modern bmx sealed set?
Maybe some road bikes use em?
Failing all that Peregrine did their sealed peds in the 90's in 1/2" fella, but they'll cop you £20:
http://bmxmuseum.com/forsale/122740
« Reply #8 on: July 09, 2014, 09:04 AM »
It's not looking good buddy but those Perry peds may just save the day. Anyone ever took a set apart? Would be great to see the internals before I splash the cash  ;)
Offline Dannywhac
« Reply #9 on: July 09, 2014, 09:20 AM »
Ere you go Clint - Stu of the Disco persuasion did a conversion from 1/2" to 9/16" to other year with piccies:
http://www.radbmx.co.uk/forum/index.php/topic,166279.0.html
« Reply #10 on: July 09, 2014, 11:28 AM »
Magic, I thought I had seen a thread like that somewhere  :)
Offline Gary72
« Reply #12 on: July 10, 2014, 12:22 AM »
Cheers Gary, I did see those but the shaft between the thread and pedal body is too long for my plans :(
