976235
ludwig242
April 29, 2026, 08:48 AM
1/2" axle sealed bearing pedals???
Topic: 1/2" axle sealed bearing pedals??? (Read 2077 times)
oldschoolace
Team Moderator
Double Flip Whip
Bodger
July 08, 2014, 04:15 PM »
Need some modern 1/2 inch sealed bearing pedals for a little project, whats out there going cheap guys? All the wellgo type pedals i can find on the bay dont specify the bearing type
oldschoolace
Team Moderator
Double Flip Whip
Bodger
Re: 1/2" axle sealed bearing pedals???
July 08, 2014, 09:39 PM »
Any ideas gents?
chubby
BMX Nerd
Needs Pegs
July 08, 2014, 10:16 PM »
You just want to use the spindles & bearings from em clint
chubby
BMX Nerd
Needs Pegs
July 08, 2014, 10:21 PM »
Are plastic peds more likely to use sealed bearings
oldschoolace
Team Moderator
Double Flip Whip
Bodger
July 08, 2014, 10:34 PM »
I need the lot Richard, need to take some accurate measurements for the bearing rebates etc. All the modern stuff seems to be 9/16 or loose ball when it's 1/2
Gary72
Site Supporter
BMX Nerd
July 08, 2014, 10:52 PM »
Not sure on the fesability, but could you not just re-thread the 9/16 down to 1/2?
oldschoolace
Team Moderator
Double Flip Whip
Bodger
July 08, 2014, 11:12 PM »
I thought of that but trying to avoid it if possible
Dannywhac
BMX Nerd
return of the whac
July 09, 2014, 08:58 AM »
I think you're stuffed on modern one's Clint - maybe ask over at Flatland Fuel as those hoppity little bunnies regularily use 1-piece cranks fella and might know of a modern bmx sealed set?
Maybe some road bikes use em?
Failing all that Peregrine did their sealed peds in the 90's in 1/2" fella, but they'll cop you £20:
http://bmxmuseum.com/forsale/122740
"Listen. I don't care what you say. Chlamydia is a soup."
(Phelps, L. 2000)
oldschoolace
Team Moderator
Double Flip Whip
Bodger
July 09, 2014, 09:04 AM »
It's not looking good buddy but those Perry peds may just save the day. Anyone ever took a set apart? Would be great to see the internals before I splash the cash
Dannywhac
BMX Nerd
return of the whac
July 09, 2014, 09:20 AM »
Ere you go Clint - Stu of the Disco persuasion did a conversion from 1/2" to 9/16" to other year with piccies:
http://www.radbmx.co.uk/forum/index.php/topic,166279.0.html
(Phelps, L. 2000)
oldschoolace
Team Moderator
Double Flip Whip
Bodger
July 09, 2014, 11:28 AM »
Magic, I thought I had seen a thread like that somewhere
Gary72
Site Supporter
BMX Nerd
Reply #11 on:
July 09, 2014, 08:09 PM »
http://www.ebay.co.uk/itm/NOS-Odyssey-old-school-bmx-pedals-vintage-old-school-bmx-sealed-bearings-/121278268094?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item1c3cbf82be
This guy is on here somewhere, think it's one of the JT's
oldschoolace
Team Moderator
Double Flip Whip
Bodger
Reply #12 on:
July 10, 2014, 12:22 AM »
Cheers Gary, I did see those but the shaft between the thread and pedal body is too long for my plans
