976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 29, 2026, 10:24 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Need 2 know what these 24 inch forks are ????
Author Topic: Need 2 know what these 24 inch forks are ????  (Read 2270 times)
« on: July 09, 2014, 06:58 PM »
I think they may be Tange TRX ? Great tig welds  ;)
thanks in advance Steve  ;)
Offline Devilock
Re: Need 2 know what these 24 inch forks are ????
« Reply #1 on: July 09, 2014, 07:26 PM »
Just check the steerer tube to determine if they're Tange.
Offline Devilock
« Reply #2 on: July 09, 2014, 07:30 PM »
Actually the dropouts do look like TRX...but TRX legs are oval.
« Reply #3 on: July 09, 2014, 07:43 PM »
Not all were oval tho  ??? Kuwi ET forks r round but TRX  ::)
Can't look at steerer as I don't have them  :D
Offline Devilock
« Reply #4 on: July 09, 2014, 07:57 PM »
Yes but aren't they just Kuwahara forks...?
« Reply #5 on: July 09, 2014, 08:10 PM »
Ok  :daumenhoch:
Offline antiquebmx
« Reply #6 on: July 09, 2014, 08:23 PM »
hard to tell but look like trx to me any other pics?
« Reply #7 on: July 09, 2014, 10:01 PM »
Agreed on the TRX.  :) Cant see if oval or round though.  :-\
« Reply #8 on: July 09, 2014, 10:06 PM »
As far as I can tell they look round . Could they b tange made Akisi ?
« Reply #9 on: July 10, 2014, 01:04 PM »
That looky like the ones  ;) Taar  :daumenhoch:
« Reply #10 on: July 10, 2014, 07:59 PM »
They'll be stamped Tange on the steerer and also if they're Kuwahara the steerer will be a bit longer than normal since the Kuwahara 24 has a 5" head tube.
do they have a flat line on inside and front face of forks ?
« Reply #11 on: July 10, 2014, 09:01 PM »
They have a 4mm ridge on the back and inside of the fork legs  ;)
« Reply #12 on: July 10, 2014, 11:43 PM »
What those forks are, I would say they are long, well longer than 20" forks, but not as long as 26" forks.
 :tumbleweed:
Thank you
monkian
« Reply #13 on: July 11, 2014, 04:39 PM »
I've had some 24" TRX and they've all been for 4" Head-tubes & made to the same spec as 20" TRX (Oval Tubes with flat edge front & rear, Internal Spiral Stem etc). Maybe the Tange made 24" Kuwahara TRX for 5" HT had round tubes like their 20" versions? They should all be stamped in the same sort of place ;)
« Reply #14 on: July 11, 2014, 07:24 PM »
A couple of more pics showing ridges  ;)
« Reply #15 on: July 12, 2014, 10:27 AM »
U lot are ace  :4_17_5: the forks r stamed like that with Tange 21  ;) Prob solved  :daumenhoch:
Thanks guys  ^"^
