976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 29, 2026, 04:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tioga Beartrap BB Question
Author Topic: Tioga Beartrap BB Question  (Read 1762 times)
monkian
« on: August 02, 2014, 05:31 PM »
Got this Tioga CK-170BT BB Set...
Never used one before but should the Adjusting Cone & Stationary Cone be the same?
Other BB Sets tend to have different Cones (usually one with integral nut & one with a notch type thing).
Has anyone else got one of these Sets to compare with? :-\ ???
Offline snoopy72
Re: Tioga Beartrap BB Question
« Reply #1 on: August 02, 2014, 08:08 PM »
looks like 2 of the same side, is one a right hand thread and one a left ? do they both screw on the shaft ?
monkian
« Reply #2 on: August 02, 2014, 08:40 PM »
All fits together Ok. You can use either one on either side.
Offline snoopy72
« Reply #3 on: August 02, 2014, 09:28 PM »
Well in that case, they probably made them both the same style because it's cheaper to make one type rather than two types or they put 2 left hand ones in the box by mistake , have you tried google imaging  the part number and see if they are all like it.
monkian
« Reply #4 on: August 02, 2014, 09:45 PM »
Yeah, could well be the case :daumenhoch:
I had trouble finding a decent image online and the Tioga Catalogue only shows one side.
I've just found an early Tange CK-170 Set in my stash and that has x2 of the same Cones on it but it'd be good to see a like-for-like comparison.
It'll probably work alright but I'd just like to know if they're all the same.
I found this shot, which is hard to tell be could the same:
Offline snoopy72
« Reply #5 on: August 03, 2014, 06:59 AM »
I had an original 80's CV-170 They were different threads but had the same adjusting nut on both sides (identical) even though only the left side was adjustable (less machining costs)
« Last Edit: August 03, 2014, 07:04 AM by snoopy72 »
monkian
« Reply #6 on: August 03, 2014, 12:41 PM »
Someone must have one of these!! ???
