976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 28, 2026, 06:02 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Built my wheel but not all of the spokes sit correct??
Author Topic: Built my wheel but not all of the spokes sit correct??  (Read 1527 times)
Offline Bowlingracecardriver
« on: October 12, 2014, 02:49 PM »
Hi there
I have just swapped the hub over from my old wheel to my new (to me) wheel and I have a slight problem. All around the wheel the spokes are sat like this.
PA130457 by Bowling Racecar Driver, on Flickr
What have I done wrong and how can I rectify it?
Thanks for your help dudes.
Rob
Offline CustardLips
Re: Built my wheel but not all of the spokes sit correct??
« Reply #1 on: October 12, 2014, 03:02 PM »
Alright Rob,
I've built quite a few wheel sets then I take to my lbs to get them trued. All the wheels I've built tend to look the same as yours so you've nowt to worry about mate. I put it down to the rim being slightly out of shape.  :daumenhoch:
"WWG1WGA"
« Reply #2 on: October 12, 2014, 03:27 PM »
So I just need to get it trued and it will all be rad from there on in?
Offline CustardLips
« Reply #3 on: October 12, 2014, 04:12 PM »
Yep... should be ok mate
"WWG1WGA"
« Reply #4 on: October 12, 2014, 04:25 PM »
Sweet! Will take it to my local BMX shop and see what they can do. Cheers for the help dude I was mega worried that my wheel will never be the same again!
leehunt1
« Reply #5 on: October 12, 2014, 05:03 PM »
tighten each nipple until they all have the spoke about 2-3 mm below the slot then start the truing process
they will all come into line
Offline bmxband1t77
  • '77 a good year (Star Wars-Punk) but not my DOB.
« Reply #6 on: October 16, 2014, 08:37 AM »
Take care spokes don't poke through or punctures will ensue!
If they do I spose you either file or grind them down. Or get a shop to look at it.
From iThing Apple Alien Tech on Tapatalk
Offline bmxband1t77
« Reply #7 on: October 19, 2014, 12:44 AM »
Just been looking at rims and specifically double lined rims for strength. Most look like the additional lining will sit over the spoke holes so harder to tighten but less likely to poke thru and cause punctures.
Might help some poor soul?
Offline CustardLips
« Reply #8 on: October 19, 2014, 10:14 AM »
As long as you've got the correct size spokes there should be no need for filing or grinding  "nono". Only an :nickswan: would use spokes that are too big.  ::)
"WWG1WGA"
