976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 27, 2026, 11:27 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bullseye crank question
Author Topic: Bullseye crank question  (Read 2428 times)
  • Andy
« on: October 30, 2014, 03:55 PM »
Hi all. I really like the look of bullseye cranks like these
I just have a few questions. Does anyone know if they ever came in chrome as well as colours? I'm thinking of fitting them to my next build which is an '84. Are these cranks era correct for the build? Any tips on what to look out for when buying a set of these? Are there any weak spots/parts that are impossible to get hold of? Hoping someone can help- thanks!
Offline eddie kidd
  • 22 years 23 days 24 minutes
Re: Bullseye crank question
« Reply #1 on: November 07, 2014, 07:31 PM »
Bullseye gear is top class...
You'll be after the Gen 2's without the safety key...
•1st gen-V1 19mm spindle - Side bolt spider mounting, Hollow spindle 1974-1975+
•1st gen-V2 22.2mm spindle - Side bolt spider mounting, Full hollow spindle,No end cap,No saftey washer key. 1976-1977+
•1st gen-V3 22.2mm spindle - Side bolt spider mounting, welded saftey end cap and safety washer. 1979-1980+
•2nd gen-V1 22.2mm Spindle - TA Cyclotourist spider plate mounting. 1981-1985+
•2nd gen-V2 22.2mm Spindle - TA Cyclotourist spider plate mounting. Safety Key washer non drive side. 1985-1990+
•3rd gen-V1 22.2mm Spindle - 3 piece Hurricane arms, Tapered drive to TA Spider plate. 1992+
From a BULLSEYE Authorized Distributor...
Wanted Green Oakley B2 Grips...Nos...
  • Andy
« Reply #2 on: November 07, 2014, 10:13 PM »
Thanks  :daumenhoch:
Offline steve69
  • aka. Steve Changa
« Reply #3 on: November 07, 2014, 10:25 PM »
I'm 95% sure I read somewhere that they didn't do them in chrome as it weakened them  :-\
I was tempted to do mine in chrome but never got round to it (Wardy told me NO !)
Offline bodamus
« Reply #4 on: November 07, 2014, 10:43 PM »
Mine are chrome ;)
  • Andy
« Reply #5 on: November 08, 2014, 04:31 AM »
Mine are chrome ;)
Originally, or did you have them re-chromed? So any idea what gen the cranks in the first photo are? They look a different shape to the chrome ones to me, or is that just the angle/light/bling effect of the chrome?
Offline steve69
  • aka. Steve Changa
« Reply #6 on: November 08, 2014, 07:09 AM »
The chrome ones do look different because of the bling but mainly because they are much longer, so proportionally differences.
You can't tell which version of  2nd gen cranks the black ones are without seeing the other side.
In the breakdown of differences, where it says.....
I think it should say....
•2nd gen-V2 22.2mm Spindle - TA Cyclotourist spider plate mounting. Safety Cap screw and washer non drive side. 1985-1990+
Offline bodamus
« Reply #7 on: November 08, 2014, 07:22 AM »
No they are rechromed with a spider gen 2's I think they are 177mm . I used to have a set with an intergrated power disc aswell.
Offline Discostu
  • Two's Company
« Reply #8 on: November 08, 2014, 12:04 PM »
I need to sell my chrome set.
  • Andy
« Reply #9 on: November 08, 2014, 02:31 PM »
Thanks for all the info. They are something i'm considering. I have my JDB Hutch cranks lined up for the VDC if it can be re-chromed ok. If it can't, then i'll powder it white and probably use bullseye cranks, either black or white.
Offline factory pilot
« Reply #10 on: November 08, 2014, 05:28 PM »
Bloody hell Andy ... Bullseye cranks WTF!! The lunacy of this VDC build is going off the scale !!! I love love love it!!  :daumenhoch: :smitten: :smitten: :smitten:
