976233 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 27, 2026, 01:19 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Shimano DX lever installation ????
Author Topic: Shimano DX lever installation ????  (Read 2454 times)
Offline southern andy
« on: November 15, 2014, 03:59 PM »
WTF........
Am i daft, cause i cant see for the life of me how to attatch the cable and the outing  :-\
Anyone got any pictures of how to do it ????
should have stuck to Tech 3's  :LolLolLolLol:
« Last Edit: November 15, 2014, 04:24 PM by southern andy »
Offline HUTCHMAN
Re: Shimano DX lever installation ????
« Reply #1 on: November 15, 2014, 04:06 PM »
lots of inner cable exposed, then feed the barrel into the body of the lever and hook it over the two little forks that are inside the body of the lever.. sorry Andy, not very good at describing stuff.  :-[
Offline That Swan Guy
« Reply #2 on: November 15, 2014, 04:11 PM »
Or go completely cable out and thread it through but the method above works for me :daumenhoch:
« Reply #3 on: November 15, 2014, 04:18 PM »
Barrel of inner cable needs to sit behind these two prongs Andy  ;)  What Dave has said basically .
It's a piece of piss when you know how  :D
« Reply #4 on: November 15, 2014, 04:24 PM »
Bloody thing, i even have to take a grip off to fit it  >:( >:(
I'll do it another day, friggin thing.
Cheers Chaps  :)
Offline HUTCHMAN
« Reply #5 on: November 15, 2014, 05:09 PM »
Guess I'm just a lazy git... I've always just bent the clamping strap until it went over the bars..
« Reply #6 on: November 15, 2014, 07:10 PM »
Thought of that Dave, but knowing my luck, i'll bust it mate.
Offline Twesnik
« Reply #7 on: November 17, 2014, 07:28 AM »
Yes, these slide over the Bars & If they're painted  you could easy strip the paint off with these Levers.....
Good Brake tho.....
Offline bmxband1t77
  • '77 a good year (Star Wars-Punk) but not my DOB.
« Reply #8 on: November 17, 2014, 08:31 AM »
Used to love these bitd. So bleedin light. Pain in bootie to fit tho.
I used to chop some card (approx 1-2mm thick- try bogroll insert) to a couple or more inches wide and fit over bars wrapping it around a bit. Then gently ease open the clamp and slide it over the card. Clamp should spring enuff open.
Alternatively go round the bar where you mount the lever with a bit of electrical tape. Tho i did  have a dx cut into the tape once when i was being sloppy stoned.
Fiddly but hope that helps?
Jonboy
Stay RAD Forever
BMX Pimpin' since '81
« Reply #9 on: November 17, 2014, 08:00 PM »
I just bent it like Dave said  :slayer:
So it's fitted to the bars but sod the cable, struggling to work that out.  :LolLolLolLol: I'll do it another day. :)
Offline bmxband1t77
« Reply #10 on: November 17, 2014, 09:26 PM »
Phew!!!😮
Jonboy
Stay RAD Forever
BMX pimpin' since '81
Offline bmxband1t77
« Reply #11 on: November 17, 2014, 10:20 PM »
Andy I've just found this hope it helps? Basically DX are weird. They push the sleeve not pull the cable.
Text from webs:
This is hard to explain but here goes. I assume you have brake lever and grip installed. DX lever pushes the cable housing instead of pulling the cable, keep this in mind and it makes it easier to work out.
The round bit on the end of the cable -----o needs to go through the lever completely and sits on a hook section which is normally covered by the grip flange. peel grip flange back and you will see hooked section. hooking this on is easiest when lever depressed and cable loose.
Next the metal end of the cables outer housing (called the housing ferrel if memory serves me) should rest on the section at the side opposite the grip, you should see another two small hooks to hold it in place (you will see this section move when you move the lever).
Thats it, now get the caliper conected and adjusted and that should be you working...lol
Jonboy
Stay RAD Forever
« Reply #12 on: November 23, 2014, 06:55 AM »
Make sure you have the plastic clip inside the lever that the cable ferule goes into; they often drop out and go missing.  Without the plastic clip you won't get the cable to pull  :daumenhoch:
Offline BMXOAP
« Reply #13 on: January 29, 2015, 09:08 PM »
Good advice. They don't work as good as tech 3's though I went from the dx's to tech 3's and never looked back :) the dx's are damn pretty though lol
