976233 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 26, 2026, 01:14 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crank set help
Author Topic: Crank set help  (Read 2052 times)
Offline stupops
Crank set help
« on: January 30, 2015, 08:27 PM »
Hi Guys
just need some help. I have a 26' SE racing quadangle. its got  American bb and a three piece 180mm crank with a 19mm spindle. will a european crank set fit it? or do i have to have the entire thing replaced. trying to make it as light and quick as possible and i am pretty sure the stock crankset is not up to much. thanks chaps.
Re: Crank set help
« Reply #1 on: January 30, 2015, 09:26 PM »
Put up some pictures, you'd be surprised how strong they'll be.
Offline stupops
Re: Crank set help
« Reply #2 on: January 30, 2015, 09:35 PM »
just use the bike for cruising. i am too old these days to thrash around! i was looking to lighten the bike and get a smoother quicker ride.
Re: Crank set help
« Reply #3 on: January 30, 2015, 09:48 PM »
They'll probably hollow steel cranks which will be about as light as most cranks to be honest.
Bung up some pictures of your bike and people might be able to suggest bits to change for you?
Lighter kevlar tyres?
New lighter wheel set?
Offline VOIVOD
Re: Crank set help
« Reply #4 on: January 30, 2015, 10:27 PM »
 No a Euro BB will not fit.Unless you use one of these..http://harriscyclery.net/product/truvativ-bottom-bracket-conversion-american-to-euro-adapter-1335.htm
A few companies make them,shop around:)
Offline stupops
Re: Crank set help
« Reply #5 on: January 30, 2015, 10:43 PM »
mavic rims
halo spokes
halo clickster freewheel
thickslick tyers
se slayer hubs
avid speed 7 calipers and levers
DMR flat mag pedals
Richy seatpost
ODI lock on grips
it looks like fab (to me anyway) and rides lovely. although replacing cranks a bb is a right job. i fear i am just spending money for no good reason!!!
Re: Crank set help
« Reply #6 on: February 02, 2015, 07:32 AM »
only two things wrong with that.
1. The seat angle is a bit wrong
2. THOSE BARS!  they need to be inline with the forks, it's not an old school bike with shyte geometry  :daumenhoch:
Offline Devilock
Re: Crank set help
« Reply #7 on: February 02, 2015, 08:12 AM »
I concur with Rob.
If you need the bars in that position to ride comfortably then you have the wrong size frame.
Re: Crank set help
« Reply #8 on: February 03, 2015, 12:44 PM »
I concur with Rob.
Or the seat too far forward...
Just needs a little fettling and fitting and will look cool  :daumenhoch:
Offline 58 delray
Re: Crank set help
« Reply #9 on: February 04, 2015, 10:41 AM »
has that not got a Euro bb anyway ?
rodriguez
Re: Crank set help
« Reply #10 on: February 04, 2015, 11:35 AM »
Cool bike   :coolsmiley:
Looks set up for cruisin, ie, sitting on the seat leaning forward, putting the seat up and moving the bars back will give a similar postition.
Coventional bike fitting suggests you sit on the seat and balls of feet on pedals legs should be slightly bent with knees over the pedals, much easier on the knees for us old farts.
Profile cranks would look good on it.
http://www.winstanleysbmx.com/product/33590/Profile_3Piece_GDH_RHD_Cranks_Without_Bearings_?gclid=CjwKEAiAo8emBRCX_OqU4qek6y8SJACzgf8fjMSIHUj_s3NaFgWqh0co77_p5qM_lvfq7f3Lj0T16RoCEGTw_wcB
« Last Edit: February 04, 2015, 12:03 PM by rodriguez »
Offline stupops
Re: Crank set help
« Reply #11 on: March 22, 2015, 08:27 AM »
Cool advice. Thanks chaps. Will make some adjustments.
Offline stupops
Re: Crank set help
« Reply #12 on: March 22, 2015, 10:17 AM »
Hi Guys
Right. I am being a total numpty here. I have never had a threadless headset before. My last bike was a mongoose decade in the 90's!!
I have moved the bars back so that they are following the angle of the forks. Now when I ride it they bars feel way to low (I am 6ft 1). I just tried to raise the headset and realised that I cant really as the stem is attached to the forks and there is nothing to play with. do i need new forks with a longer bit that goes through the tube on the frame? thanks guys.
Offline VOIVOD
Re: Crank set help
« Reply #13 on: March 24, 2015, 01:59 PM »
 :) Yep-looks like the steerer tube on your forks is too short to raise the stem any higher.Try taller bars and/or a riser stem.
