976233 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 26, 2026, 08:09 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Anyone Done An Oven Pride Strip On A Black Tange Headlock??
Author Topic: Anyone Done An Oven Pride Strip On A Black Tange Headlock??  (Read 1299 times)
« on: February 20, 2015, 10:21 PM »
And if so, were the results good?
And if so, any tips?
Offline Funkyworm
Re: Anyone Done An Oven Pride Strip On A Black Tange Headlock??
« Reply #1 on: February 22, 2015, 08:43 PM »
Yes mate,
Are you talking about an LP-440 ?
If so mine Came out fine,  little tip if you want to get the existing bare alloy bits really shiny. Stick them on a wheel with a little peek polish & they come up like glass.  :daumenhoch:
Offline Gary72
« Reply #2 on: February 22, 2015, 09:18 PM »
Keep checking it and don't forget about it.
I ruined a set of crank arms because I forgot about them, Ended up getting SBD to powder them.
Dan told me about using caustic soda.
« Reply #3 on: February 22, 2015, 09:31 PM »
I'm ok ta guys, I swapped it for a red one with Lenny.
Cheers for replies though.  :daumenhoch:
Offline Funkyworm
« Reply #4 on: February 22, 2015, 09:33 PM »
Stick it in a plastic bag & use Oven Pride or Dr Magic Oven & Grill cleaner.. it's about £1 from cheap stores.. give it 5-10 mins & keep rubbing the bag to work off the anno. if you leave it a long time it'll turn black.. a Scotch brite pad or those harsh green scouting squares will take that off but try not ti let it go that far.
You'll be fine  :daumenhoch:
Offline 58 delray
« Reply #5 on: February 23, 2015, 09:28 AM »
caustic soda is way better than oven pride, easier to see whats going on and control the results  :daumenhoch:
