976228 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 18, 2026, 11:21 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Time to start the Marlboro woody build
Author Topic: Time to start the Marlboro woody build  (Read 28884 times)
Offline fischflo
Re: Time to start the Marlboro woody build
« Reply #25 on: March 30, 2015, 08:32 PM »
typical Clintism... lets see whats he up to again....:laugh:
« Reply #26 on: March 31, 2015, 06:18 PM »
3 hours of planishing and needle file work and it still looks shite.  :LolLolLolLol:
At least the bubble gum seam welds are gone now. Hopefully the other lugs won't put up as much of a struggle
Offline john4130
« Reply #27 on: April 01, 2015, 05:54 AM »
were the main tubes brazed in? looks like i can see a bit of brass. couldnt you try heating them to see if they come out or is that the size your working too.
« Reply #28 on: April 01, 2015, 07:53 AM »
They are brazed and my first thought was to try and remove them. After a chat with Phil I decided against it as the heat needed to release the joints is alot great than it is to braze. The extra steel should add a bit more strength too
Offline chubby
  • Needs Pegs
« Reply #29 on: April 01, 2015, 06:42 PM »
To your snooker cue's ???
« Reply #30 on: April 02, 2015, 04:06 PM »
After measuring every conceivable angle, length and diameter i went in big time with the angle grinder. Those with a nervous disposition or children present look away now
« Reply #31 on: April 02, 2015, 04:43 PM »
 :2gunsfiring_v1: >:D :daumenhoch:
More pics please!
Offline chubby
  • Needs Pegs
« Reply #32 on: April 02, 2015, 05:05 PM »
Gonna need a fair few nails to hang that back up now chum  :teef
« Reply #33 on: April 02, 2015, 05:12 PM »
Nitromors.....  ::)
How can it not be against the law to sell something that doesnt do what it claims to do  :2gunsfiring_v1:
Offline chubby
  • Needs Pegs
« Reply #34 on: April 02, 2015, 06:13 PM »
Nitromors.....  ::)
Chuck some methelyne chloride in it  :daumenhoch:
« Reply #35 on: April 04, 2015, 05:55 PM »
So it turns out paint stripper does work.... you just have to leave it overnight then resaturate it with another coat  ::)
Anyway time to do something about those bubble gum welds and weld spatter. These things really were thrown together  ;D
Before
After..... ALOT of grinding
Almost ready for some wet or dry and a bit of polishing  :daumenhoch:
« Reply #36 on: April 04, 2015, 10:03 PM »
Thought about reshaping the drops or drilling them but I don't want it to end up looking too fixie ish so the original drops are staying  :)
« Reply #37 on: April 10, 2015, 03:08 PM »
Sorry i dont have any more pics. Sanding shitty old, low end, wanky welded drops is a complete arse  >:(
« Reply #38 on: April 13, 2015, 02:43 PM »
That's what a dremel is for  :LolLolLolLol:
« Reply #39 on: April 14, 2015, 04:36 PM »
Got bored grinding away with my dremel  ;) on the drops so went back to the head tube today. Another lunch hour gone she is almost there and well pleased with the results given how badly flaired the fork end was  :daumenhoch:
« Reply #40 on: April 14, 2015, 07:17 PM »
Top clean up job
« Reply #41 on: April 14, 2015, 10:40 PM »
Tomorrows job is to build the GT Pro bars jig for steam bending  :)
Offline bobbbbsy
« Reply #42 on: April 14, 2015, 11:06 PM »
did you just grind off the excess clint ?
« Reply #43 on: April 14, 2015, 11:17 PM »
No. It all got knocked back round a solid steel rod the same diameter as the inside of the head tube. I bought a planishing hammer to do it properely.
Took a while, but coaxed it back a treat  :daumenhoch:
Offline bobbbbsy
« Reply #44 on: April 14, 2015, 11:20 PM »
nice . oh . was it all out of wack inside the headtube ?
Offline chubby
  • Needs Pegs
« Reply #45 on: April 14, 2015, 11:22 PM »
Some mighty fine fettling there chum  :shocked:
« Reply #46 on: April 14, 2015, 11:23 PM »
Yeah, because someone had been running round on it with no bearings the leading 5-6mm funneled out like the end of a trumpet
Offline bobbbbsy
« Reply #47 on: April 14, 2015, 11:25 PM »
bereft of brains  ::) . did nt they know you been looking for a fully lugged zapper for 3 yrs ??
Offline bobbbbsy
« Reply #48 on: April 14, 2015, 11:27 PM »
you cold set it all >?
« Reply #49 on: April 14, 2015, 11:33 PM »
Yep. Luckily the edge hadnt flaired to the point of forming a crack
