976233 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 26, 2026, 11:37 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  aero reflex headset??
Author Topic: aero reflex headset??  (Read 1465 times)
Offline Kezturbo
« on: March 29, 2015, 02:58 AM »
Hi guys if you have seen my previous post I have brought a NIB aero reflex f+f I've been looking at headsets and does anyone know if the tange mx-2 headset fits? Or is there any recommendations from owners out there.this is my first build so bear with me I may be bothering fellow owners about parts that fit save me the hassle of buying wrong parts and a lot of swearing.it will be mainly about headsets and cranks
Cheers in advance :)
Offline workshyfop
Re: aero reflex headset??
« Reply #1 on: March 29, 2015, 03:07 AM »
tioga beartrap/beartrap 2, hattta mx10..or the tange mx2 will fit, as long as its a 1 inch bmx threaded headset variant.
Offline deeman
« Reply #2 on: March 29, 2015, 01:22 PM »
yep the mx-2 will be fine, although a lot swear by the Tioga beartrap if you are riding the bike in any kind of anger. any 1" headset for threaded forks will do you. Much better to ask questions than get it wrong the hard way!   :daumenhoch:
Offline Gnarlyscoots
  • BANNED
« Reply #3 on: March 29, 2015, 01:42 PM »
I got an MX-2 on mine fella   :daumenhoch:
Make sure you got the shim for the seat post though. You will need it if you are going to fit a standard 22.2mm post.
BANNED
Offline Kezturbo
« Reply #4 on: March 29, 2015, 05:38 PM »
 Cheers chaps :) yep its good to ask first as you guys have prob tried and tested.frame is on its way it was posted on friday so should get it hopefully tomorrow or tuesday.it should have shim in box but will find out
« Reply #5 on: March 29, 2015, 07:41 PM »
If its not loose in box, check in the seat post tube itself!  :-\  :daumenhoch:
Offline factory pilot
« Reply #6 on: March 31, 2015, 04:35 PM »
Beartrap 2 all the way of you are going to ride it ... It defo stays tight tight tight!  :daumenhoch
I've got s tange on mine though and it lasted on Saturday in Chester!  :daumenhoch: 8)
