976232 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 25, 2026, 10:39 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  DX resto question
Author Topic: DX resto question  (Read 1947 times)
Offline 58 delray
DX resto question
« on: May 26, 2015, 10:12 AM »
how easy is it to replace the pins on DX pedals and what should i replace them with if it is possible ?
Offline laidback
Re: DX resto question
« Reply #1 on: May 26, 2015, 10:23 AM »
I've heard that welding rod is a good replacement...i'm about to restore some of mine. there's caps on ebay at the moment if you need any :daumenhoch:
Offline 58 delray
« Reply #2 on: May 26, 2015, 11:19 AM »
i have caps, its just the studs i need, will look into the welding rod  :daumenhoch:
Offline fischflo
« Reply #3 on: May 26, 2015, 10:33 PM »
Some tips here, not looked into it, but might be worth a look - check out Griff's especially the 'dowel pins!' one sounds promising............ http://www.radbmx.co.uk/forum/index.php/topic,169353.0.html ............ :smiley6600:
Offline HUTCHMAN
« Reply #4 on: May 27, 2015, 07:41 PM »
ok, one suggestion... i used to work for Stuart Turner pumps many years ago and have a fair knowledge of the stuff they did for their line of model steam engines. Long story short, Stuart Models, now in Bridport, do a range of stainless steel rod.. eg 3/32 , 1/8 and upwards . About £4.50 for a 12 inch rod. feel sure this may be preferable to welding rod ??
http://www.stuartmodels.com/products/fittings--tools---accessories/materials
hope this is of use.
Offline 58 delray
« Reply #5 on: May 28, 2015, 10:53 AM »
many thanks  :daumenhoch:
