976232 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 25, 2026, 02:34 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Can anyone recommend a paint stripper to sort out a pair of spray-painted DX?
Author Topic: Can anyone recommend a paint stripper to sort out a pair of spray-painted DX?  (Read 2644 times)
Never stripped paint off anything before, only ano
Seem to recall someone saying nitromors wasn't much cop anymore and that Synstrip was good
Trouble last I've only found it for sale so far in 5L containers (which is probably a lot just for a pair of pedals  :teef: )
Can anyone recommend something that will do the job? Or post a link to this stuff being sold in slightly less industrially-sized amounts?
Offline john4130
nitromors will be fine for a pair of dx, put it on thick and let it sit for 5-10 mins then give it another coat, it will probably start coming off while giving it the second coat. use a toothbrush to get into the tight bits.
Cheers John  :daumenhoch:
Offline insectbones
Nitromors is fine if you keep it 'wet'....
Splash it on and wrap in clingfilm for a bit  :daumenhoch:
Offline steve69
  • aka. Steve Changa
DX's have the thinnest layer of paint ever so you won't have a problem getting it off. You may want a little artists brush to get in all the angles though.
It's by no means the original paint, someone's just rattle-canned them black so hopefully won't take much to shift it
Offline wilsey72
  • Thats corn that is.
Put it on with a dabbing motion. Dab Dab Dab...
GLOUCESTER RIDE 28th July 2018
