976297 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 02:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Is this a restore or refinish?
Author Topic: Is this a restore or refinish?  (Read 7841 times)
Offline Old School
« on: September 22, 2015, 03:33 PM »
Hi guys,
Just got this from oldscool on here ;)
Can anyone tell me if this is worth giving an Oxalic bath?
Or is it a shot blast and re-chrome?
There are plenty of scratches and marks and pits.
I would say there are chrome chips too.
Also, the part that joins the bottom bracket with the looptail looks to be slightly concave - is this normal or heavy use??
Cheers as always :daumenhoch:
Re: Is this a restore or refinish?
« Reply #1 on: September 22, 2015, 03:46 PM »
I'd say its ALWAYS worth a citric acid bath and then re-assess  :daumenhoch:
Anything you can do to save the original finish has to be good... give it a good 24 hr sock in 500g og Citric and give it a good Peek'ing and see how it looks :-)
« Reply #2 on: September 22, 2015, 04:57 PM »
Its only going to be original once
Offline CustardLips
« Reply #3 on: September 22, 2015, 06:53 PM »
A bloody good soak and a bloody good polish and I'm sure that'll come up sweet... what've you got to lose  :daumenhoch:
"WWG1WGA"
Offline Old School
« Reply #4 on: September 22, 2015, 09:18 PM »
I wholeheartedly agree, shot blast and pc is last resort!
Is citric acid same as Oxalic acid?
How do I remove the decals?
Does anyone on here do repop decals?
Offline chubby
  • Needs Pegs
« Reply #5 on: September 22, 2015, 10:00 PM »
Use citric acid & it won't hurt the decals bud. Takes a bit longer than oxalic but is safer to use, should be a good "how to" by oldschoolace in the tech stickies  :daumenhoch:
« Reply #6 on: September 22, 2015, 10:20 PM »
Big tub
500g of Citric Acid off of Ebay
as hot as water as possible ... enough to cover the frame ... but bricks in around the frame to cut down on the water you need
mix in the Citric acid
soak for 12hrs ... check it ... another 12hrs if needed
good peek polish
sorted
rodriguez
« Reply #7 on: September 23, 2015, 12:56 AM »
Try and save the original finish and decals  :daumenhoch:
Looks to be better condition than my pug before I started   :-\
http://www.radbmx.co.uk/forum/index.php/topic,174737.0.html
To remove chrome properly you have to have the process reversed by a plater, shot blasting it isn't the best way to go AFAIK.
Offline insectbones
« Reply #8 on: September 23, 2015, 06:18 AM »
Big tub
good peek polish
sorted
While it's in the bath, give the rusty spots a rub with a toothbrush  :daumenhoch:
Citric works great. I've got a thread on here somewhere on a rusty as fook Catweasle, it came out lovely.
I didn't like it shiny though, so chucked it in the garden to go rusty again  ;D
Offline insectbones
« Reply #9 on: September 23, 2015, 06:27 AM »
Here ya go
http://www.radbmx.co.uk/forum/index.php/topic,178191.msg1789151.html#msg1789151
Your squashed bit is probably from a stand being fitted and over tightened, nowt to worry about  :daumenhoch:
Offline Ady
« Reply #11 on: September 23, 2015, 08:14 PM »
That would come out near minty with a oxy bath :daumenhoch:
Nice DB  :)
Offline sparky
« Reply #12 on: September 24, 2015, 06:20 PM »
The box section looks like it might have had a kickstand attached at some point, that or something which has caused the concave. You might also want to check the fork rake because they look a little off-set going by the angle of the headstock tubing.
Offline Old School
« Reply #13 on: September 25, 2015, 04:21 PM »
Thanks guys, ace advice as always!
Mark, how do you mean the forks are offset and what am I looking for?
Sorry if it's obvious!
Couple of other questions:
Cheers :daumenhoch:
Offline hokuspokus74
« Reply #14 on: September 25, 2015, 05:30 PM »
Old school use a heatgun or hair dryer to remove the decals,then if there is sticky residue after you remove them spray wd40 on it and use a white scourer pad as it wont scratch the F&F DONT USE GREEN, on the resto stickys you will see where it says dels new website or something hes the main man for decals top class job ;)
Offline sparky
« Reply #15 on: September 25, 2015, 10:50 PM »
Cheers :daumenhoch:
From the picture angle it looks like the fork legs have been bent back.
Offline Old School
« Reply #16 on: September 26, 2015, 06:26 PM »
Cheers :daumenhoch:
Mmmm, interesting, it does look different!!
There's a serial number on the forks....does this help to know if they're Silver Streak forks?
Offline Old School
« Reply #17 on: September 26, 2015, 06:52 PM »
Good job I got the Senior Pro off twoscoops33 then!!
Haven't got it out of the box yet but that looked ready to go from the photos!
Will build that while I sort this out properly ;)
Offline sparky
« Reply #18 on: September 26, 2015, 08:50 PM »
Cheers :daumenhoch:
Forks are correct for a Silver Streak
Offline Old School
« Reply #19 on: September 26, 2015, 10:22 PM »
Is that yours? What pedals are they?
Offline sparky
« Reply #20 on: September 27, 2015, 02:06 PM »
Used to be. They are DB MKS pedals which were not factory fitment.
Offline tfi_friday
« Reply #21 on: October 05, 2015, 05:38 AM »
Is that a crack in the drop out, from the diamond?
Offline Old School
« Reply #22 on: October 06, 2015, 04:47 PM »
Oooh, well spotted!!
Will check when I get home, cheers mate!
Could well be tbh, as Sparky has already pointed out the forks aren't angled correctly anymore either!!
See photo at top of thread, then his photo- BIG diff!
Sent from my iPad using Tapatalk
Offline deeman
« Reply #23 on: November 22, 2015, 03:21 PM »
As said before...use a hairdryer or heat gun to soften the decals and peel them off but clean the residue with thinners/ solvent. Del is the man for decals...del@del-cals.co.uk
Offline factory pilot
« Reply #24 on: November 22, 2015, 03:53 PM »
It is amazing what you can do with a few hours of blood, sweat and tears .. Give it a go dude.. If it works you'll be smiling from ear to ear !  :daumenhoch:
