976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 04:03 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Advice on bottom bracket
Author Topic: Advice on bottom bracket  (Read 3160 times)
Offline Noste500
« on: September 28, 2015, 07:30 PM »
Be gentle , I'm learning ;-)
I need to buy a new bottom bracket bearing set for my gt fueler 1995.
When I look at options it offers 19mm or 22mm .
I've measured the threaded part of my 1 piece crank and its 22mm outer diameter .
Also I note from my model its a USA size bb.
Does this mean I need a 22mm size bearing set ?? (I realise I need the USA option )
Seem to be more 19mm on offer ...
Don't want to buy the wrong one 😉
Cheers in advance
Offline That Swan Guy
Re: Advice on bottom bracket
« Reply #1 on: September 28, 2015, 07:42 PM »
Glenn 19 should be fine. I'll pop one over to you when I find a brake  :daumenhoch:
Offline Gary72
« Reply #2 on: September 28, 2015, 07:47 PM »
Sounds like your looking at 3 piece crank bottom brackets and you have a 1 piece crank :)
Offline Noste500
« Reply #3 on: September 28, 2015, 07:53 PM »
Thanks Nick 😊
What does the 19/ 22mm denote on the descriptions online ?
Is is the diam of the threaded part of the crank ?
Offline Gary72
« Reply #4 on: September 28, 2015, 08:02 PM »
it refers to the diameter of the axle. Most 3 piece cranks use either a 19mm or 22mm sliding axle.
There are some exceptions. There are 20mm, 24mm and some imperial sizes like 7/8 and 1 inch.
Pop up a pic of what you have.
« Reply #5 on: September 28, 2015, 08:08 PM »
It's a regular OPC Gary
Offline Noste500
« Reply #6 on: September 28, 2015, 08:22 PM »
Need to learn the lingo OPC .. One piece crank ?? ;-)
With verniers its 22mm on threaded part ..
Are the sealed ones worth the extra ££ ?
« Reply #7 on: September 28, 2015, 08:44 PM »
Yes sorry One Piece Crank  :LolLolLolLol:
Any bottom bracket that states One Piece Crank will fit. As for sealed, yes they are better but only to a point, depends how hard you're going to ride it. Tange/tioga ones are probably the best value for money
Offline Gary72
« Reply #8 on: September 28, 2015, 08:55 PM »
I guessed that from his 1st post, It sounds like he his looking at bottom brackets for 3 piece cranks, Thats where the 19mm and 22mm came in.
Bearing sizes are not normally quoted on OPC bottom brackets.
Offline Noste500
« Reply #9 on: September 28, 2015, 09:25 PM »
Gotcha ,
This is correct then ?
http://www.alansbmx.com/221813/products/etc_one_piece_crank_bottom_bracket.aspx
Hope I'm not breaking any rules puting a link up . Let me know if I am fellas .
« Reply #10 on: September 28, 2015, 09:25 PM »
Gotcha ,
that'll do it :daumenhoch:
Offline OllyHall
  • Dannywhac is a fooking hippy!!
« Reply #11 on: October 05, 2015, 04:53 PM »
I often wonder if this hobby is becoming a fashion statement it's a opc bb did you ever ride?
Mid school baby!!
Offline Noste500
« Reply #12 on: October 05, 2015, 09:11 PM »
That's helpfull .
Why don't you just not bother .
Thanks to other posters , I got it sorted ;-)
Offline bmxband1t77
  • '77 a good year (Star Wars-Punk) but not my DOB.
« Reply #13 on: October 05, 2015, 09:15 PM »
One piece cranks usually quote the thread size like 24tp than the bearing /axle size often quoted on three piece cranks.
Good on you sticking a one piece on. I do like a good old redline flight but all that spacer and alignment bollox  I'm having a break from that!!!!
