976228 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 19, 2026, 12:28 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  HTF does the SR Spintech work?
Author Topic: HTF does the SR Spintech work?  (Read 1762 times)
Offline That Swan Guy
« on: March 05, 2016, 12:53 AM »
I can't remember these badboys from bitd but IF I had a spintech, what should I have and how does it work?
Re: HTF does the SR Spintech work?
« Reply #1 on: March 05, 2016, 10:44 AM »
It's reliant on a few small parts to work Nick. Unfortunately those often get lost  :(
Will dig you a diagram out :daumenhoch:
« Reply #2 on: March 05, 2016, 10:55 AM »
Here you go  :daumenhoch:
http://bmxmuseum.com/forums/viewtopic.php?id=187724
Note the ball bearing at the end of the cable fixing bolt!
these often go missing as do the bolts, the upper adjusting bolt and the nylon sheath for the stem shaft  >:(
« Reply #3 on: March 05, 2016, 11:14 AM »
Holy fook!
I only want to ride my bike not build a spaceship! :LolLolLolLol:
« Last Edit: March 05, 2016, 12:59 PM by That Swan Guy »
Offline deeman
« Reply #4 on: March 05, 2016, 12:58 PM »
Top info right there Clint  :daumenhoch:
Blooming hell it looks complex! do they work any better than anything else?  :-\
« Reply #5 on: March 05, 2016, 02:55 PM »
I've only ever set mine up briefly just out of curiosity. Its a more logical system as your are getting a more even/squarer pull that a normal rotor but i imagine people would argue till the cows come home which rotor system is the best.
I like it, but as with most rotor sytems it has its limitations  :)
Offline chubby
  • Needs Pegs
« Reply #6 on: March 09, 2016, 10:15 PM »
Pain in the arse,  Thumbs down
Offline chubby
  • Needs Pegs
« Reply #7 on: March 09, 2016, 10:21 PM »
« Reply #8 on: March 10, 2016, 10:32 AM »
I found my spintech on my decade very good. I have to say though it baked my noodle a bit until i realised that the top cable its the outer sheath that moves and not the inner cable!!
