976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 07:08 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spit and polish
Author Topic: spit and polish  (Read 3316 times)
Offline Ady
spit and polish
« on: March 05, 2016, 10:41 PM »
Well been a busy week and just finished this frame this weekend .
Never done it before with the proper gear as I normally use the good old elbow grease  "nono"
This machine make it so easy and takes half the time..
Before..
After.. :smitten:
 :radbmxsmilie:
Offline Gary72
Re: spit and polish
« Reply #1 on: March 05, 2016, 10:56 PM »
 8)
Offline deeman
Re: spit and polish
« Reply #2 on: March 05, 2016, 11:07 PM »
Top work bro  :daumenhoch:
Offline Ady
Re: spit and polish
« Reply #3 on: March 05, 2016, 11:09 PM »
took bloody ages`s ..
And I ache like fook... ::)
But worth it..
Cheers bud.. :daumenhoch:
Offline Taipan
Re: spit and polish
« Reply #4 on: March 06, 2016, 12:25 AM »
Great work  :daumenhoch: what a difference  :daumenhoch: now show us said machine you used  :)
Offline sawzall
Re: spit and polish
« Reply #5 on: March 06, 2016, 09:50 AM »
nice bit of resto :coolsmiley:
Offline Ady
Re: spit and polish
« Reply #6 on: March 06, 2016, 11:15 AM »
I bought this..
http://www.ebay.co.uk/itm/Bench-Grinder-Polisher-350w-6-General-Purpose-Metal-Polishing-Kit-TZBG-6002-/281625045051
And this to get into the hard areas ..
http://www.ebay.co.uk/itm/281774044831?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
But..
Having a few issues with this machine..
I gets hot with continuous use and just applying the compound blocks to the polishing wheel its enough to stop the momentum and stall the machine.
Even too much pressure when polishing this frame it stops and gets a humming sound.
Its ok from the start as it will not stall but after a hour or so using it for a long time it gets hot then stalls ..
Have any of you guys had this issue before as to be honest a hour of continuous use its going to get hot and possibly a fail safe built into it..
Or its shite  :LolLolLolLol:
Re: spit and polish
« Reply #7 on: March 06, 2016, 11:33 AM »
Cracking job :4_17_5:
That machine ain't cut out for it long term. I have a bench grinder with a mop mounted on one side. It's much more powerful but will still slow down if I go at it too hard. Never stopped it or heard the motor humming though
Offline factory pilot
Re: spit and polish
« Reply #8 on: March 06, 2016, 11:34 AM »
Great job Ady!
Andy and I spent the other night working on my aero pro in a similar fashion .. You've done it proud fella! It's well worth all the effort mate :daumenhoch:
Re: spit and polish
« Reply #9 on: March 06, 2016, 11:39 AM »
This is the sort of thing I have, was about 40 quid from b&q years ago. Just removed the right hand wheel, shields and guard and fitted a mop cone :daumenhoch:
how long did it take you to get clean :LolLolLolLol:
Offline Ady
Re: spit and polish
« Reply #10 on: March 06, 2016, 12:00 PM »
it gets bloody hot..
too hot to touch it mind..
I have requested a refund and will upgrade to a more heavy duty one than this if they refund me.
Well..
I started Tuesday as I just finished my man cave .
Around 2hrs a night off and on when the shite like EastEnders is on and most of the afternoon on Saturday gone.
I Say 10 hrs of work..
I did spend 2 hrs with the wrong polishing pad and had to go back and start again.. ::)
Its a job of patience trust me I haven't got it..
But worth the effort..
Just two more frames to go.. :teef:
Offline insectbones
Re: spit and polish
« Reply #11 on: March 06, 2016, 12:05 PM »
A very complex frame to polish  :shocked:
Turned out well  :daumenhoch:
Offline deeman
Re: spit and polish
« Reply #12 on: March 06, 2016, 01:34 PM »
It sounds like you need something a little more heavy duty Ady! In case you didn't know, a good way to clean the mops as you are using them to stop them getting clogged is to hold a stiff wire brush over it hard in between applying the compound as and when needed  :daumenhoch:
« Last Edit: March 06, 2016, 06:35 PM by deeman »
Offline Ady
Re: spit and polish
« Reply #13 on: March 06, 2016, 02:35 PM »
Cheers D..
Was using a heavy duty scraper but only removes the surface .
The wire brush is a great idea so thanks for that..
Yes..
Going to get a more heavy duty unit as this one is not up too it..
But there polishing products are great.. fistblump
Re: spit and polish
« Reply #14 on: March 06, 2016, 06:18 PM »
Great work there and well worth the effort.  :4_17_5:
Offline raddad
Re: spit and polish
« Reply #15 on: March 11, 2016, 02:58 PM »
Looks awful Ady, do it again.
Jim.....
