976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 06:36 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stripping Zinc plating using sulphuric acid
Author Topic: Stripping Zinc plating using sulphuric acid  (Read 3844 times)
  • Andy
« on: June 07, 2016, 10:46 PM »
I bought a Raleigh Burner last year that needs a full resto. The steel rims were too far gone to polish up, so I took them to be stripped & re-chromed. The hubs also needed re-chroming. As burner spokes are a thicker gauge than standard spokes, I carefully removed them, put them to one side and polished the nipples up (took about 4 hours)!. The spokes were dull and had started to rust, so I took them to my local friendly chromer (Leigh metal polishers) who suggested that zinc plating them would be the best idea. A few weeks later I picked up my lovely shiny spokes, and took them, the rims and hubs to my local bike shop to get the wheels built up.
I went into the bike shop to check on their progress, but was told the spokes wouldn't screw into the nipples as the zinc plate had filled in the threads. As these spokes aren't readily available, I thought about a way to strip the threads to make them fit. I found out that most acids will dissolve zinc plate - some people use vinegar but it takes a while. I couldn't wait that long, so I decided to look for some sulphuric acid (car battery acid), which supposedly works better and faster. After a few calls to car parts/motor factors shops, I found a local one that stocked the stuff (£9 for decent sized bottle). I also found out that bicarbonate of soda (baking soda) can be used to neutralise the acid once you're done. So I went to the supermarket and bought:
A starbucks coffee drink in a glass bottle to use as a suitable container
Baking Soda, which I mixed with water
Washing up gloves (pink of course) as seconds skin to my heavy duty workmans gloves
De-ionised water to prevent unwanted reactions - probably didn't need it, but what the hell
a container to neutralise the acid once done
a funnel
nice shiny zinc plated spokes
with threads that were useless as full with zinc
sulphuric acid
I used a roughly 50/50 mixture of acid and water. Just enough to cover the spoke threads
spokes then went in - I did 72 spokes in 2 goes, as the neck of the bottle was too narrow to do them all at once. I wore goggles and 2 pairs of gloves throughout the process
the reaction was instant. Fizzing nicely, with a bit of heat given off that could be felt through the bottle. An exothermic reaction I seem to recall from my GCSE chemistry days  :daumenhoch:
It took about 20-25 minutes for the zinc to come off. I removed the spokes, dunked them in the baking soda solution, then used a small wire brush to remove any stubborn bits of zinc. I then dried the spokes and gave them a very quick polish with some peek to remove any stains.
and here you go - the spokes now fit and screw into the nipple  :D
I'm not sure if sulphuric acid will remove other forms of plate such as copper, nickel or chrome. I don't think so, and some metals/processes can be dangerous/harmful, so take your parts to the experts if you aren't sure.
Offline CustardLips
Re: Stripping Zinc plating using sulphuric acid
« Reply #1 on: June 07, 2016, 10:51 PM »
Nice work Andy.  :daumenhoch:
"WWG1WGA"
  • Andy
« Reply #2 on: June 07, 2016, 10:57 PM »
Thanks Nick  :daumenhoch:
If anyone needs any acid, I have a tub full! Can't post it, so collection only  :LolLolLolLol:
Offline Taipan
« Reply #3 on: June 08, 2016, 12:25 AM »
Top tip  :daumenhoch:
« Reply #4 on: June 08, 2016, 02:28 AM »
Great how to that Andy  :daumenhoch:
Offline insectbones
« Reply #5 on: June 08, 2016, 07:20 AM »
Great work Andy  :daumenhoch:
Top tip  :coolsmiley:
Offline SteveG
« Reply #6 on: June 08, 2016, 09:50 AM »
This explains why the plating came off some go-kart hubs. The chrome rims were rusty so I soaked them in vinegar for a while, didn't really fix the rims but the hubs were nice and clean !
I need to rebuild some old racer wheels with double butted spokes and your tip will make getting them plated a lot easier, thanks.
Offline nosepickben
« Reply #7 on: June 08, 2016, 03:10 PM »
Excellent guide there Andy. You'll have to measure the diameter of 72 and 96 spokes then find a corresponding beverage receptacle for precise fit if you ever repeat the job.
« Reply #8 on: June 08, 2016, 03:13 PM »
Black Marigolds are available you know  ::)
  • Andy
« Reply #9 on: August 29, 2017, 09:05 PM »
**BUMP**
 :radbmxsmilie:
« Reply #10 on: September 03, 2017, 07:58 PM »
Great thread this  :daumenhoch:
Good work  :4_17_5:
Offline chubby
  • Needs Pegs
« Reply #11 on: September 04, 2017, 09:17 PM »
Great results Andy, I  love volatile chemicals, bit overboard on the safety gear for me though.  :teef:
« Reply #12 on: September 05, 2017, 12:09 AM »
