976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 04:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stuck and cut seat post
Author Topic: Stuck and cut seat post  (Read 2068 times)
Offline Ste
« on: June 12, 2016, 08:49 PM »
Just got a frame I've been after for a long time but unfortunately it has a seat post stuck in it, to top it  off the last owner has (for some reason) cut the seat post flush to the seat tube  >:(
Any ideas on how to remove it would be much appreciated as I'm all out of ideas
Cheers fellas..
Re: Stuck and cut seat post
« Reply #1 on: June 12, 2016, 08:51 PM »
Drill the seat post out gradually
Offline Ste
« Reply #2 on: June 13, 2016, 06:39 AM »
I tihink that is the only option as I'm never gonna get a good bite on it now, thanks dude.
« Reply #3 on: June 13, 2016, 08:33 AM »
Is it a a steel post in a steel frame?
Offline Ste
« Reply #4 on: June 14, 2016, 06:41 AM »
It's an alloy post in a steel frame
« Reply #5 on: June 14, 2016, 06:58 AM »
I'm sure there's a "how to..." thread but an alloy post can be disolved with acid that won't touch the steel frame.
Not got time to search but this is definitely the way forward unless you have access to a machine shop and actually less risky of damaging the frame.
However if you need the tube extending afterwards you might just be better off getting it replaced so Phil Sawzall on here is your man. The guy is a legend with a welder  :coolsmiley:
EDIT:
Here you go, I just typed in "stuck alloy post" in the search function and ta-da, a load of threads with the answer.
http://www.radbmx.co.uk/forum/index.php/topic,134819.msg1301955.html#msg1301955
« Last Edit: June 14, 2016, 07:10 AM by Spen69 »
« Reply #6 on: June 14, 2016, 08:12 AM »
Try this too.
http://www.radbmx.co.uk/forum/index.php/topic,178937.0.html
caustic works great but it's nasty stuff and if its a thick post it can take a while. It can also have a "welding" effect so once you start you have to see it through
Offline Ste
« Reply #7 on: June 15, 2016, 08:26 PM »
Think I'm going to give Phil a shout as there's a few other bits I'd like to get sorted on the frame, thanks for the shout well  appreciated, I'd make a right mess with the acid route  :daumenhoch:
