976229 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 23, 2026, 12:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Haro Mirra 540 Air - restoration
Author Topic: Haro Mirra 540 Air - restoration  (Read 16788 times)
Offline Dogfish
« on: July 01, 2016, 08:49 PM »
Starting my first restoration of a early 2000 Mirra Air .. Not the most exiting bike compared to some of the gear on here but will be nice when done ..
Picked the bike up on Wednesday one thing I did notice was how heavy the bike is when loading in the boot ..
The bike can be best described as tatty but functional I think if it was a motorbike it would be classed as a rat bike ..
The bike as far as I can see is very well made and all the parts look serviceable.
I have most the tools and stuff to restore things as I have restored 4 motorbikes so this should not be too much of a problem but saying that if anyone has any experience on these bikes the help will be appreciated ..
The plan is to keep the costs in check and not get carried away and restore the original parts rather than getting carried away on eBay etc .. I will aim to make it look like new in the original colours ...
First quick questions is there a company that sell the decals ??
I will post up a few pictures and keep posting updates ...
Offline Dogfish
Re: Haro Mirra 540 Air - restoration
« Reply #1 on: July 01, 2016, 09:13 PM »
Ignore the dumb question spotted the sticky for dels decals  :P
Offline solow79
« Reply #2 on: July 05, 2016, 08:55 PM »
Any pics of the bike? Ive got a bit of a soft spot for turn of the century Haro's.
Offline chrisv39
« Reply #3 on: July 06, 2016, 08:26 PM »
Let's see some pics mate we need more build threads on here
« Reply #4 on: July 08, 2016, 10:08 PM »
I wouldn't mind seeing this too  ::)
Offline fischflo
« Reply #5 on: July 11, 2016, 04:03 PM »
I wanna see this bike  8)
Offline Dogfish
« Reply #6 on: July 12, 2016, 07:02 PM »
Hi Guys here she is .... rough around the edges but all there and serviceable ...
The intention is to restore the on a budget of £50 ....  :LolLolLolLol:
Offline Dogfish
« Reply #7 on: July 12, 2016, 07:07 PM »
here's a few more
You could run a tractor crank on those bearings !!!
« Last Edit: July 12, 2016, 07:09 PM by Dogfish »
Offline Dogfish
« Reply #8 on: July 12, 2016, 07:11 PM »
Wheels are in good nick need a clean and the spokes could do with a polish ..
Offline fischflo
« Reply #9 on: July 13, 2016, 03:09 PM »
I like it, sturdy looking machine that  :2gunsfiring_v1: screaming kneesavers.       ...... and mabe different tyres
Offline fischflo
« Reply #10 on: July 14, 2016, 12:27 PM »
Like these primo v monsters f.ex ->http://bmxmuseum.com/forums/viewtopic.php?pid=3886904#p3886904       ....the decals kinda boring, but what the fook, it's a Dave Mirra.  :slayer:
« Reply #11 on: July 14, 2016, 08:54 PM »
Looks good as it is from the photo's.  8) Strip and a clean could be suffice.  :daumenhoch:
Offline Dogfish
« Reply #12 on: July 17, 2016, 07:20 AM »
They hide the truth mate ... The paint is rough ..
I have made some progress this week had an afternoon in the garage I managed to get the decals off the bike they are knackered but could be copied I think this is going to be the expensive part of the build .. Under the decals the paint was new sort of gave me the boost of energy to get on with it I can see what the bike could be ..stripped most the paint from the frame keeping in mind my tight budget I did this by hand wishing I had taken it to the shot blaster after 2 hours ..
Will post up a few pictures when I get the laptop out ...
Just a quick couple question for anyone who can help what size is the bottom bracket bearing on these bikes looks like 19mm and can you replace individual spokes to re spoke a wheel the spokes ain't that bad but for £8 for a set it will make a big difference to the bike ..
Kit list of parts needed
Head bearings
Wheel ball bearings
Gyro cables top and bottom
Front brake cable
Tyres tubes and tape
Bottom bracket bearings and covers
pedals
Brake blocks
Need to get all this for 50 quid  :slayer:
« Reply #13 on: July 17, 2016, 09:09 AM »
Post up a wanted ad.  :daumenhoch:
[/quote]
Head bearings
Wheel ball bearings
Front brake cable
pedals
Brake blocks
:slayer:
[/quote]
Offline fischflo
« Reply #14 on: July 17, 2016, 11:46 AM »
1) bearing - Yeo, should be American bottom bracket, 19 mm bearing size.     ... I think   :D
2) decals-  have alook, could be the set you need -->http://bmxmuseum.com/forums/viewtopic.php?id=400240       .....in case our own decal mäster del aint got a set
3) spoke individually - sure you can respoke individual spokes. Looks You need Spokes 2.0mm straight gauge ( https://knowyourbike.com/haro/mirra-540/2000 )
Edit: about 1) yep should be 19 mm, äs i've seen a 1999 Model with 19mm (http://bmxmuseum.com/bikes/haro/63623 darkian's) and a 2003 also running 19mm (http://bmxmuseum.com/forums/viewtopic.php?id=230792  wired's resto (post #25) )
« Last Edit: July 17, 2016, 01:03 PM by fischflo »
Offline Dogfish
« Reply #15 on: July 18, 2016, 01:30 PM »
Thanks guys .. those builds really are top work gives me ideas for this build ...
Here's a bit of a close up of the frame ... just in case the picture hid the real state of the bike but for £20 what can you expect ...
Quick update
painted the bar clamp with Halfords satin which looks near to the original finish used a thin coat of etching primer on a well degreased surface, then thin coast of satin .. looks pretty good ... also prepped and painted the bolts with "plasticote" chrome they look ok I might replace these at a later date with zinc coated of polish .. the bolts look allright at a glance ..
Made a start on the frame I could have taken this down the bead blasters but in the spirit of this built I am prepping by hand .. I like the wealds and general quality of the frame it really is well made ... the frame has a few small dings nothing to get upset about I was thinking of polishing the frame but the dings will show if I paint it I can "hide" them ...
Starting to get into this now ... will crack on this week as not so busy with work etc ...
Paul
« Last Edit: July 18, 2016, 01:51 PM by Dogfish »
Offline Dogfish
« Reply #16 on: July 18, 2016, 10:54 PM »
I had a good go at the frame this evening was tempted to start the process of polishing but thought I would stick to the plan anyway I gave it a bit of a trial run with the "BMW Jet black" ...
« Reply #17 on: July 19, 2016, 08:07 AM »
Looking like it's coming together well for £20 mate.
As said above, if you're on a tight budget bang up a wanted list of exact parts (19mm BB bearings for instance) and I'm sure people will have stuff  :daumenhoch:
Offline Dogfish
« Reply #18 on: July 20, 2016, 03:42 PM »
thanks again I will put a list on the wanted page ... I saved the gyro and bottom cable ..
Had a "working from home" day today with the kids at the child minders and the Mrs at work ...
I finished prepping the frame and got the etching primer on will blow a coat of black on it later after it has "baked" in the sun good job the mrs is at work .... bit like putting parts in the dish washer  :knuppel2:
Offline Dogfish
« Reply #19 on: July 20, 2016, 03:57 PM »
Another problem solved ... the sprocket has a nice design on it my sprocket if rough and will need painting ...
I was racking my brains on how to get this back on the painted sprocket easy answer get a sign writer on the job ... my dad retired years ago but can still sign write when needed ... only cost me a few tins of beer ...
this is the original design
« Reply #20 on: July 20, 2016, 08:15 PM »
Can't beat a dishwasher for cleaning parts.  ;D  :daumenhoch:
Offline Dogfish
« Reply #21 on: July 20, 2016, 11:25 PM »
Bit more of an update ...
I put a coat of black on later this afternoon which took a whole can of paint I needed to get another coat on found a tin of Peugeot Graphite grey which will do as a base coat I am fatting it back anyway ... sort of growing on me the graphite idea I might see if Halfords have a really dark graphite near black ...
Pretty much finished the back wheel as well
Offline fischflo
« Reply #22 on: July 21, 2016, 12:44 AM »
nice to see the progression on the Mirra :daumenhoch: to 'simply' go for the sprocket design repaint, pretty wild
....concept of that drying rack really takes balls :LolLolLolLol:
Offline Dogfish
« Reply #23 on: July 21, 2016, 10:19 PM »
Today I had to go to work so not much progress had a go at stripping the forks have my first real problem ..
the head bearing has a golf ball effect can you get replacements without replacing the frame part ?? be a shame to have to start knocking the frame about ... if anyone has this part please let me know
cheers
paul
« Reply #24 on: July 22, 2016, 07:12 AM »
Is it just the bearing race you need?
