976228 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 18, 2026, 03:03 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rickman Racing Pro - 'Rusty Rick'
Author Topic: Rickman Racing Pro - 'Rusty Rick'  (Read 21853 times)
Offline Chez-6
Re: Rickman Racing Pro - 'Rusty Rick'
« Reply #25 on: July 11, 2016, 07:03 PM »
 :daumenhoch: looks like the Ugly ducking might just turn into a Swan after all, Great Work  :4_17_5:
« Reply #26 on: July 11, 2016, 07:06 PM »
Come on martin get it in the citric
Offline dinglem
« Reply #27 on: July 12, 2016, 12:49 PM »
Bath is on the way.... Currently en route to work though so there will be a bit of a progress delay for the time being. I was in a rush to break it down to F&F state as I have dropped it off with the guys who helped restore our early Mini. They are very sympathetic and have agreed to dip the frame for me so hopefully I'll have some results piccies soon  :coolsmiley: I didn't trust myself doing my first citric bath on this particular example!
I should just also add how much of a blind pig the seatpost removal was... ended up cutting it off an inch above the frame, filing down the back of the inner seatpost to create a groove and then carefully sawing in said groove with a hacksaw blade right to the bottom of the seatpost, crushing it inwards once cut and then pulling it out. We put a solid bar in the top inch and closed a vice hard onto it, then hammered the frame off it using a block of wood (and lots of WD40).
« Reply #28 on: July 14, 2016, 04:08 AM »
Looking forward to seeing this one come back to life!
Offline dinglem
« Reply #29 on: July 15, 2016, 10:32 AM »
Just a quick observation as I have seen several posts elsewhere saying there is no date code for Rickman Racing frames.
Mine starts with 25 001 on the first line, which signifies a race frame. 25 002, or 003, or 004 signifies the various levels of freestyle frames.
I am there told the lower line of the serial number is the frame number itself.
In my case I have 065 08 on the second line.
Now to me that signifies a June '85 frame based on the first 3 digits, as per the Ammaco date stamping pattern. Having looked at all of the other Rickman frame serial numbers I can find online they exhibit the same pattern, with the first 3 digits showing would could represent a month and year pattern corresponding to an '84 or '85 timing. The space and subsequent number means mine is the 8th frame made that month.
My question is to all of the other Rickman owners... could you please post up whether you have a stamping that doesn't fit in with this pattern? I guess we're looking at numbers higher than 12 for the first two digits and not a 4 or a 5 (or a 6?) for the year??? I could have course be wrong but I haven't seen an example that doesn't fit this pattern yet....
Offline dinglem
« Reply #30 on: July 15, 2016, 10:40 AM »
Looks like I might have been proven wrong already as a few owners have already messaged me with numbers that don't appear to match the pattern. Arseflakes. Oh well....
  • Andy
« Reply #31 on: July 15, 2016, 03:39 PM »
What a story, thread and build. This is going to turn out lovely. Absolutely top class work so far. Can't wait to see it all done  :daumenhoch:
Offline CustardLips
« Reply #32 on: July 17, 2016, 12:54 PM »
Wow... that's in need of some serious tlc. Looking good so far though.  :daumenhoch:
« Last Edit: July 17, 2016, 03:09 PM by CustardLips »
"WWG1WGA"
Offline dinglem
« Reply #33 on: July 18, 2016, 09:59 AM »
Well the super-rare Rickman forks can certainly be saved!
Amazing bath results.
Frame going in next - hopefully it turns out just as well!!!  :daumenhoch:
« Reply #34 on: July 18, 2016, 03:55 PM »
Top work.
Are you thinking a rechrome, or fresh white powder?
Offline dinglem
« Reply #35 on: July 18, 2016, 04:57 PM »
Here's the frame, literally just out of the bath.
Totally solid!   :laugh:  There is a bit of light surface pitting on the looptails, but that's about it. An amazing transformation really. I think I could probably very fine sand the surface on the loops and it would then stand a rechrome, but failing that it'll be white as per other Rickman race bikes I have seen. I'd prefer chrome if possible though.
I'm over-the-moon with the result.
Offline Dogfish
« Reply #36 on: July 18, 2016, 04:58 PM »
Now that looks like a real project ...
« Reply #37 on: July 18, 2016, 05:05 PM »
Gotta love citric acid, came out great  :daumenhoch:
« Reply #38 on: July 18, 2016, 05:52 PM »
Superb
Offline kalex
« Reply #39 on: July 18, 2016, 08:26 PM »
You definitely need a pat on the back for this
Offline chubby
  • Needs Pegs
« Reply #40 on: July 18, 2016, 11:35 PM »
Unbelievable result Mart, what do they use in the tank bud ???
  • Andy
« Reply #41 on: July 18, 2016, 11:40 PM »
Excellent work. I can't believe it's the same bike!
Offline dinglem
« Reply #42 on: July 19, 2016, 12:11 AM »
I have no idea what they used... I did ask today but they wouldn't tell me!! It obviously works though, and my fears of lots of holes in the tubing (and me leaving it in too long if I had done it myself) were unfounded.
I'm just excited to start working out how I'm going to build it now. I might tot up the build total cost for this one as I reckon it'll be a bargain basement job seeing as I got the frame and forks  for so little. I've been after one for ages so i'm getting a real buzz out of this.
I had considered the white finish, but prefer chrome. I just found this too, which seems to confirm they did come in both chrome or white finishes from the factory.
Offline chubby
  • Needs Pegs
« Reply #43 on: July 19, 2016, 12:14 AM »
Whatever it was I want some 😀
Deffo not citric, wouldn't of taken the finish off like it has
Sent from my HTC One M9 using Tapatalk
« Reply #44 on: July 20, 2016, 01:17 PM »
Blimey, what a result  :4_17_5:
« Reply #45 on: July 20, 2016, 08:23 PM »
Great thread.  :daumenhoch:
What a great find and great results too.  :coolsmiley:
Looking forward to seeing built up.  :daumenhoch:
Offline Andy68
« Reply #46 on: July 21, 2016, 09:04 AM »
Looking good Mart....... MY O.P. Racing was similar..... not quite as bad bud the citric bath worked a treat.
I'm no expert on the serial no's but have 2 sets of forks, both stamped 25 021.  :daumenhoch:
Offline dinglem
« Reply #47 on: July 21, 2016, 10:34 AM »
Thanks for all of the comments guys - it certainly has been a bit of a revelation so far.
I didn't even know the forks were stamped Andy (where?) I'll have to have another look over mine, or are yours the freestyle versions?
Offline dinglem
« Reply #48 on: July 21, 2016, 11:01 AM »
Well that didn't take too long to research.
Not sure what number mine has but here's a few examples found online.
Offline Andy68
« Reply #49 on: July 21, 2016, 11:01 AM »
Whats freestyle????  :LolLolLolLol:
Inside of left dropout Mart  :daumenhoch:
