976228 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 18, 2026, 07:55 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fakelifter Potts bolt help
Author Topic: Fakelifter Potts bolt help  (Read 2905 times)
Offline brimfull
« on: October 10, 2016, 11:14 PM »
I've recently picked up a Forklifter style stem but it has a solid bolt and I need a Potts bolt for it.
Any ideas on what sorts will fit and where to get one would be greatly appreciated
Many thanks in advance
Offline deeman
Re: Fakelifter Potts bolt help
« Reply #1 on: October 11, 2016, 02:24 AM »
If you can post a pic up of the bottom of the stem and the wedge, I may be able to point you in the right direction. It will more than likely be a fairly standard bolt. You will need a photobucket or similar account....copy and paste the IMG code here.  :daumenhoch:
I imagine it will look something like this.....
http://www.ebay.co.uk/itm/Chrome-Hollow-Stem-Bolt-For-BMX-Stem-Potts-Mod-Bolt-Freestyle-Stem-Bolt-/121600344034?hash=item1c4ff1ffe2:g:gNsAAOSwwTlUp~vw
« Last Edit: October 11, 2016, 02:27 AM by deeman »
Offline Taipan
« Reply #2 on: October 11, 2016, 08:14 AM »
I think the top nut is actually longer for these stems? you might have trouble tightening that type shown up when its in place? but I could be wrong? tbh I've only seen the type listed separately that the link shows,maybe one of the fella's on here has a spare in there box of spares  :daumenhoch:
Offline Picklez
« Reply #3 on: October 11, 2016, 01:49 PM »
Agree, redline forklifter ones (and alike) have a longer 'top', more like this:
http://www.ebay.com/itm/Inverted-Dyno-Stamped-Compe-Nitro-Quill-BMX-Stem-GT-Potts-Mod-/172339812412?hash=item282040d83c:g:SqgAAOSwNSxVCw6g
Had a quick look around last night for you. Couldn't find any other than the one on the stem in the ad.
Offline brimfull
« Reply #4 on: October 11, 2016, 07:33 PM »
Thanks guys, yep they are longer and different to normal ones
This isn't my stem but you can see the bolt on it, I might be able to make one out of a two piece bolt if I can find one
Offline McQUEEN
  • I left it in the garden......
« Reply #5 on: October 12, 2016, 09:29 PM »
The freestyle ones are higher because the race stem bolts are tightened using an allen key into the center of the bolt - this doesn't work if you're running a potts mod, so the stem bolt is higher to allow you to spanner tighten them.
When I was born, the world was a far simpler place.
It was all just cops and robbers.
And BMX.
Offline brimfull
« Reply #6 on: October 12, 2016, 09:41 PM »
Hopefully got one sorted now  8)
Offline region11
« Reply #7 on: October 15, 2016, 05:56 PM »
its possible you may have to drill the stem out a bit, the redline/suntour version forklifter stems have a wider diameter freestyle bolt than the race bolt.
Neil
