976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 11:44 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tyre storage tips
Author Topic: Tyre storage tips  (Read 4787 times)
Offline Glynnyboy
Tyre storage tips
« on: November 07, 2016, 01:29 PM »
Just wondering what you do to keep yours supple?
Any tips?
Re: Tyre storage tips
« Reply #1 on: November 07, 2016, 02:03 PM »
Put them on a rim and do skids, no need to worry about storage then Glynn
« Reply #2 on: November 07, 2016, 05:34 PM »
I read that applying Vaseline to the walls helps.
Offline deeman
« Reply #3 on: November 07, 2016, 06:20 PM »
I also read a thread which stated NOT to do this Dan....Sure of it  :-\
« Reply #4 on: November 07, 2016, 06:33 PM »
That's probably what I saw Damo, my memory's shite.
rodriguez
« Reply #5 on: November 08, 2016, 12:39 AM »
Bin liners in the roof space.  :daumenhoch:
Offline Glynnyboy
« Reply #6 on: November 08, 2016, 07:06 AM »
The roof or the garage is what I've done up to now but I've had a couple dry out. The ones in boxes or packing paper have been fine. I realised it's the extremes over the year causing moisture then dry out can make them brittle.
I've gone for a squirt with simonize tyre protector  and just ordered some silica gel packs to put in the bin liners. See how that fairs .
  • Andy
« Reply #7 on: November 08, 2016, 10:26 AM »
I used to use vaseline, and mine are still supple and haven't deteriorated in 3 years. I've now switched to autoglym tyre dressing which goes on like a dream with little waste/residue. All seems good so far. I store my unfitted tyres in the house - in a wardrobe away from heat sources to keep the temp fairly constant
Offline Glynnyboy
« Reply #8 on: November 08, 2016, 11:18 AM »
That's the best option really Andy a constant temperature.
Offline McQUEEN
  • I left it in the garden......
« Reply #9 on: November 08, 2016, 05:04 PM »
I did some research into this for a house and garage I had to design the services to for a car collector. 40+ very expensive classic cars in a below ground garage in London. Constant temp and humidity is the way to go. Avoid moisture at all costs. I with DTTDB re Autogym Vinyl and Rubber care. Darkens skinwalls alittle but great on the rubber.
When I was born, the world was a far simpler place.
It was all just cops and robbers.
And BMX.
« Reply #10 on: November 08, 2016, 05:12 PM »
I would ask Alan Woods what he does with his in his stock room, all mine have come from there, and they're all still in great shape.  :D
« Last Edit: November 08, 2016, 05:32 PM by Retrodan72 »
Offline welshv5er
  • 84 Ultra Burner & 85 Team Aero Pro Owner
« Reply #11 on: November 10, 2016, 08:26 PM »
i use baby oil on my tyres, the Autoglym stuff works ok too
Offline oldscool
« Reply #12 on: November 11, 2016, 04:50 PM »
Whats all this vaseline and rubber talk. Should be in the S&M section.
If in doubt flat out.
« Reply #13 on: November 11, 2016, 04:58 PM »
I wouldn't recommend anything oil based (or vaseline), for the same reason you shouldn't use it as a sex lube with a latex condom
I also wouldn't put oil on my tyres because they're supposed to be grippy :teef:
« Last Edit: November 11, 2016, 05:01 PM by griff »
  • Andy
« Reply #14 on: November 12, 2016, 08:41 PM »
Greased up and ready for action. The tyres have had a bit of attention too.
« Reply #15 on: November 13, 2016, 01:46 AM »
I have used Timberland Waximum on the sidewalls of a set of Comp St's I have, seems to have worked pretty well so far.
Offline OllyHall
  • Dannywhac is a fooking hippy!!
« Reply #16 on: November 14, 2016, 01:55 PM »
What about them bags you suck the air out with a hoover?,  they do say on the advert they are moisture/water tight?
Mid school baby!!
