976225 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 12, 2026, 11:28 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Lock-on grip bolts
Author Topic: Lock-on grip bolts  (Read 2684 times)
Offline Mikku
  • Keeping it RAD in Japan!
Lock-on grip bolts
« on: February 04, 2019, 07:37 AM »
I want to change out the grips on my race bike but one of the little hex bolts has rounded off and I can't undo the fooker! :2gunsfiring_v1:
I've read various suggestions online about what to do in this (what seems to be common) situation, varying from using a rubber band, banging a flat-head screwdriver into it, drilling the head, hacksawing it, using a Dremel, buying a bolt extractor, etc, etc. I've already failed with the lacky band, so before I try anything else, have any RADsters had the same problem and if so, what did you do? Thanks in advance! :daumenhoch:
PS Yes, I will grease and not over-tighten the new bolts when I'm finally able to fit the new grips! fistblump
Offline BrianP
Re: Lock-on grip bolts
« Reply #1 on: February 04, 2019, 01:03 PM »
Try tapping a small Torx bit into the bolt head, you might get enough of a "bite" on that to get it unscrewed - I've done this with socket head bolts in the past and had some success with it.
Brian  :daumenhoch:
Offline Mikku
« Reply #2 on: February 05, 2019, 12:15 AM »
Thanks Brian! Not sure I have one but will have a rummage around the tool box. :daumenhoch:
Offline Mikku
« Reply #3 on: February 06, 2019, 01:12 PM »
Couldn't rustle up a torx bit, so tried wedging a small, flat-headed screwdriver in the head of the bolt. After a minute or so of hammering the fooker, I managed to get enough purchase on the bolt to unscrew it! :daumenhoch:
Which just goes to show the old adage "if in doubt, give it a clout" is alive and well! At least in this bodger's repertoire! ;D
