976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 02:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oddy A BRAKE
Author Topic: Oddy A BRAKE  (Read 3241 times)
Offline HUTCHMAN
Oddy A BRAKE
« on: March 16, 2019, 03:15 PM »
Can anyone give me any advice on setting one of these up please.... i thought i'd done it right, but it feels like a wet lettuce. Also, do i need a v brake specific lever for it ?
Thanks in advance.
Offline VOIVOD
Re: Oddy A BRAKE
« Reply #1 on: March 16, 2019, 05:35 PM »
  A v specific lever has more "pull" than u/caliper levers.A brakes are a pain in the arse to set up.Do you have the instruction sheet with them?
 Once you`ve fitted it,leave the springs pointing out-not secured by the retaining pin then tighten down the bolts before popping the springs back behind the retaining pin once you`ve got enough tension to keep the blocks from rubbing on the rim once the lever is released.
« Last Edit: March 16, 2019, 05:40 PM by VOIVOD »
Offline HUTCHMAN
Re: Oddy A BRAKE
« Reply #2 on: March 16, 2019, 05:43 PM »
Star!!... thanks for that advice  :4_17_5: ...   next question... anyone know where i can get a really nice (CNC'd) lever from in the U.K ?
Offline VOIVOD
Re: Oddy A BRAKE
« Reply #3 on: March 17, 2019, 12:58 AM »
 I don`t know if there are many CNC`d v levers around.Paul are OK but don`t have much cable pull.I`ve used the Box ones too but again they don`t have much pull for a v lever. but keep going back to trusty DXRs.I`ll be after a TRP ML 940 lever soon,had them before and are pretty neat.
Offline HUTCHMAN
Re: Oddy A BRAKE
« Reply #4 on: March 17, 2019, 06:43 AM »
yea... quite like the TRP's  :daumenhoch:
Offline Gary72
Re: Oddy A BRAKE
« Reply #5 on: March 19, 2019, 11:09 PM »
I have an instruction sheet here for the A brake.
PM me your email addy and I'll take a pic and send it to you
