976216 Posts in 138992 Topics by 6420 Members - Latest Member: churchclothes April 04, 2026, 05:12 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Grip Dying
Author Topic: Grip Dying  (Read 4868 times)
Offline Warnerlewis
Grip Dying
« on: September 29, 2019, 10:31 AM »
Can someone point in the right direction, trying to dye grips from yellow to blue, did the Google search on it, used Dylon heated to 100deg left them in for 16h pulled them out with no change in colour what so ever...
Sent from my ONEPLUS A5010 using Tapatalk
Formally Wolfiehere on here early 2000's
Offline CustardLips
Re: Grip Dying
« Reply #1 on: September 29, 2019, 06:03 PM »
Some grips will take dye and some won't. Never tried myself so not sure which tbh. ???
"WWG1WGA"
Offline hotdog
Re: Grip Dying
« Reply #2 on: September 29, 2019, 06:25 PM »
I dyed some yellow Oakley F1 sleeves to a dark blue using dispersion dye that I picked up off the internet.
  • Andy
Re: Grip Dying
« Reply #3 on: September 29, 2019, 08:08 PM »
A’me round & tri grips won’t dye. Oakley .5’s will using dylon
« Last Edit: September 29, 2019, 08:15 PM by dancetothedrummersbeat »
Offline Warnerlewis
Re: Grip Dying
« Reply #4 on: September 29, 2019, 08:18 PM »
I used Dylon I'm trying to dye Mongoose og yellow grips to blue
Offline hotdog
Re: Grip Dying
« Reply #5 on: September 29, 2019, 10:24 PM »
I did actually dye some A'me rounds from yellow to black with dispersion dye and it was successful Andy  :daumenhoch:
  • Andy
Re: Grip Dying
« Reply #6 on: September 30, 2019, 09:34 AM »
Wow, great job Tim! I tried to dye a teal pair to black using the usual rit/dylon method, and messed them right up  :'(
Online oldschoolace
Re: Grip Dying
« Reply #7 on: September 30, 2019, 01:55 PM »
Word of warning on the dispersion stuff, it is lethal if you spill it! will stain anything!
Also on a more technical note it is a dye that migrates inward over time. If you use too much dye or leave the grips too long the dye will be overloaded and start to leach out leaving a powdery residue. for a pair of grips you need NO MORE THAN A level TEASPOON in a pan big enough to take both the grips at the same time. Never let the water boil or even simmer. Just hot enough to produce steam. Black should take no longer than 15 mins. if you leave it for ages your hand will be constantly black :D
