976343
BMX1970
August 29, 2026, 09:51 PM
Rust on a painted frame
Topic: Rust on a painted frame (Read 9170 times)
Dredgy73
Riding with Stabilisers
February 16, 2021, 09:21 PM »
Hi all
What is the best way to remove rust on a painted frame?
I would like to keep it original so do not want to harm the decals....
Coke? Cif of something else?
Thanks
Midschoolfool
Flip-Whip
Re: Rust on a painted frame
February 17, 2021, 02:12 PM »
Neither.
You want to use CAP (Citric Acid Powder) or OA (Oxalic Acid)
https://www.amazon.co.uk/Citric-Acid-1kg-100-Grade/dp/B00DJI8RA0/ref=sr_1_6?crid=2TD8NNAIWCGUX&dchild=1&keywords=citric+acid+powder&qid=1613571112&sprefix=citric+acid+pow%2Caps%2C160&sr=8-6
Put the parts in a tub, put that in with water. Plenty of tutorials on the net.
Dredgy73
February 18, 2021, 08:59 AM »
Thank you 👍
CustardLips
Site Supporter
Berm Worm
February 18, 2021, 01:57 PM »
Citric acid bath how to guide...
http://www.radbmx.co.uk/forum/index.php/topic,178383.0.html
"WWG1WGA"
wildon
Flip-Whip
February 18, 2021, 02:33 PM »
Oxalic Acid works
Dredgy73
February 24, 2021, 06:18 PM »
How long do you leave it in the bath for. Added more crystals, but after a day not much is going on!
BMX1973
Site Supporter
Berm Worm
February 28, 2021, 02:23 PM »
I normally put in 1/2 - 1 kg and leave for a day. Wipe over every now and again if you can. You will see it working as the rust spots normally turn yellow.
