976342 Posts in 138998 Topics by 6443 Members - Latest Member: BMX1970 August 27, 2026, 06:15 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  3 piece crank to euro
Author Topic: 3 piece crank to euro  (Read 9447 times)
Offline watchmechromejob
« on: July 24, 2021, 10:17 AM »
Anyone managed to put 3 piece non sealed bearing crank like 401 into euro BB???
Thanks agy
« Last Edit: July 24, 2021, 10:25 AM by watchmechromejob »
Offline Midschoolfool
Re: 3 piece crank to euro
« Reply #1 on: July 24, 2021, 04:41 PM »
No. You will need a new axle, providing you can find one.
Non sealed axles have threads etc on them. I could be wrong, but you will probably find that even if there is some sort of unsealed BB for those cranks it would cost you more than it's worth.
I am 99.9% sure that Flights use a standard 8 spline axle.
https://www.ebay.co.uk/itm/254396932883?hash=item3b3b3d2313:g:1y8AAOSwpJRdrxeu
You then need umbrella bolts.
https://www.ebay.co.uk/itm/284366702521?hash=item42359387b9:g:y9wAAOSwraFg6auM
If yours are not the same (M8 fine) and a BB
https://www.sourcebmx.com/products/odyssey-euro-bb?currency=gbp
Sadly the BB ain't cheap. They are not common any more, meaning there are hardly any left. You will need a 19mm euro BB. There is one on Ebay, but the company is flaky. I ordered a set of cranks from them and they are drop shippers, meaning they don't hold stock so you usually get jerked around for a fortnight before an unexpected refund /roll eyes.
« Reply #2 on: July 24, 2021, 05:58 PM »
Thanks for the comprehensive response.
I'm just toying with possible fitments...
I like unusual setups too.
 :uglystupid2:
