976292 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 10:17 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  dying seat with Dylon?
Author Topic: dying seat with Dylon?  (Read 17854 times)
Offline ammacopij72
« on: February 15, 2022, 01:30 PM »
Have managed to source some Dylon madonna blue powder tins and am going to try dying a og 80s yellow viscount mx to blue. found this (https://bmxmuseum.com/forums/viewtopic.php?pid=7254237...) on the museum but its not clear if you have to bring the water back to the boil after adding the dye? Any thoughts or advice appreciated..
Neil
Offline hotdog
Re: dying seat with Dylon?
« Reply #1 on: February 15, 2022, 02:43 PM »
Rit dye has always worked for me with Kashi and Elina saddles. Dyed them in minutes. Just keep the pan gently bubbling away with the lid on otherwise the dye gets everywhere. The dye doesn't effect the side logos either. The biggest problem was finding a pan big enough to hang the seats into. The chinese supermarket came up trumps but they aren't cheap.
Offline ammacopij72
« Reply #2 on: February 16, 2022, 08:51 AM »
Cheers dude, ever have any issues with yellow to blue? have a had a few comments that i'll end up with green?
Offline hotdog
« Reply #3 on: February 16, 2022, 09:37 AM »
I've done yellow to black and red to black. Only ever done yellow to blue with Oakley grips.
« Reply #4 on: February 16, 2022, 02:44 PM »
Cool, I done the same also, dyed Yellow B2's to Blue no problem.
« Reply #5 on: February 28, 2022, 11:25 PM »
The key thing with the seat will be if it is Nylon. If it's not you may struggle to get the dye to take at all or end up with some hybrid wierd colour.
Kashis, Elinas, Shotguns have all been done very successfully and to be honest the process will usually even work with cold water but go for the hot pot as it will help and just stick it on a camping stove keeping it warming over throughout the process. There's guides on here if you look in the tech and resto stickies.
As for the pan to stick it in I got the 15.2L one of these : https://www.ebay.co.uk/itm/360970532712
And I just got a cheap Amazon camping stove like this : https://www.amazon.co.uk/Trespass-Gastro-Camping-Temperature-Ignition/dp/B00A162ELQ
Good luck and have fun  :daumenhoch:
