976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 28, 2026, 10:45 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Surface Rust Removal
Author Topic: Surface Rust Removal  (Read 2962 times)
poppers
« on: October 06, 2006, 05:01 PM »
What's the best thing to use to get rid of surface rust without scratching the good metal underneath too much?
duncan
Re: Surface Rust Removal
« Reply #1 on: October 06, 2006, 05:18 PM »
If it's just mild surface rust then you could try steel wool. Use the finest grade you can find, though if it's chrome you'll find it's remarkably scratch resistant.
I've read that copper or aluminium wool is better ideally, as it doesn't leave behind any residue that can rust away in nooks & crannies on the frame.
You'll know whether your frame/part is worth this extra precaution.
Oxalic acid is good for treating more serious cases of rust, handy for removing inaccessible rust inside the tubes, there are threads here on its use. Can eat the metal as well as the rust though if you leave an item submerged too long. It should be neutralised afterwards.
I use Hammerite Gel Rust remover for any deep rust, but it can be expensive if you need to use a lot of it. If it's bare metal rather than chrome you need to seal the metal with paint/lacquer/wax pretty quickly afterwards or the rust will soon return.
cd
« Reply #2 on: October 06, 2006, 08:42 PM »
see
http://www.radbmx.co.uk/forum/index.php'topic=19339.msg199061#msg199061
it is very easy - cheap to get going and is totally non-abrasive
cd
« Reply #3 on: October 06, 2006, 08:43 PM »
oxalic acid
cd
« Reply #4 on: October 08, 2006, 02:23 AM »
« Reply #5 on: October 09, 2006, 10:35 AM »
oxalic acid
« Reply #6 on: October 09, 2006, 10:36 AM »
its made from 100% pure ox
« Reply #7 on: October 09, 2006, 10:55 AM »
i had some of that. it irritatated my delicte little nose.
snav69
« Reply #8 on: October 09, 2006, 11:02 AM »
 :shocked:  :shocked: This stuff works well
Chemical Formula
C2H2O4 (anhydrous)
C2H2O4.2H2O (dihydrate)
Can you guess what it is yet??  :daumenhoch:
Answers on a postcard  :2funny:
Paul  :coolsmiley:
« Reply #9 on: October 09, 2006, 02:15 PM »
brillo pad?
snav69
« Reply #10 on: October 09, 2006, 02:20 PM »
Nope  :-X
Paul  :coolsmiley:
Offline phantom photon
« Reply #11 on: October 09, 2006, 02:22 PM »
Coca Cola?
snav69
« Reply #12 on: October 09, 2006, 02:23 PM »
nope  :-X
cd
« Reply #13 on: October 09, 2006, 10:38 PM »
oxalic acid
I set myself up for that one.......
« Last Edit: October 09, 2006, 10:40 PM by cd »
snav69
« Reply #14 on: October 09, 2006, 10:46 PM »
  :2funny:  :2funny:  :2funny:  :2funny:  :daumenhoch:
Congratulations , You're a winner  :LolLolLolLol:
Paul  :coolsmiley:
Offline showtime
« Reply #15 on: October 11, 2006, 07:59 AM »
you could always just spit on it & rub it with tinfoil  ;)
works for me :daumenhoch:
