976235 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 April 29, 2026, 02:50 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Putting grips on....
Author Topic: Putting grips on....  (Read 3234 times)
retrorb
« on: October 13, 2006, 08:32 PM »
Just putting some grips on my first build...very tight - is there a lube I can use which won't eat the plastic? to help slide them on
My wife is watching me to great amusement getting red in the face and trying to slide them on.....
Rob
snav69
Re: Putting grips on....
« Reply #1 on: October 13, 2006, 08:34 PM »
Hair Spray , slides them on easy and then they stick  :daumenhoch:  :daumenhoch:
Or you can just breath inside the grip a few times as the condensation will help also.
Paul  :coolsmiley:
« Last Edit: October 13, 2006, 08:39 PM by snav69 »
Offline Dingobmxer
« Reply #2 on: October 13, 2006, 08:36 PM »
GT85, it soon evaporates and they stay put  :daumenhoch:
 :) DINGO :)
selfpreservation
« Reply #3 on: October 13, 2006, 08:36 PM »
be carefull you dont get blisters cause youll be pissed off if you cant ride it for a week cause your w4nkin spanners are sore
snav69
« Reply #4 on: October 13, 2006, 08:38 PM »
:2funny:  :2funny:  :2funny:  :2funny:  :2funny:
zed4130
« Reply #5 on: October 13, 2006, 08:52 PM »
i use a very hi-tech substaince called spit it's great. :idiot2:
« Reply #6 on: October 13, 2006, 09:02 PM »
 :) DINGO :)
Yeah & it smells good  :daumenhoch:
Jazzchimp
« Reply #7 on: October 13, 2006, 09:53 PM »
do you know what the best thing for grips is???
spit!
Seriously.. go on try it! it has enough mucus to smooth them on and once it evaporates they are stuck!
« Reply #8 on: October 13, 2006, 10:06 PM »
spit!
Yeah but does it smell good  ;)
69ner
« Reply #9 on: October 13, 2006, 10:48 PM »
hair spray best slides on then sticks like superglue
MeddlE
« Reply #10 on: October 13, 2006, 10:53 PM »
WD40, you wont get motorcycle grip if you use that.
Offline phantom photon
« Reply #11 on: October 14, 2006, 10:00 AM »
I use Sure deodorant  - smells nice also  :daumenhoch:
Offline AtariAger
« Reply #12 on: October 14, 2006, 05:37 PM »
Actually...the best non-lube way of putting grips on is using wire ties or tie wraps.  Put like 5 or 6 into the grip with the smooth side toward the bars.  Get them spaced nicely and just slide the grips right on....then simply pull the tie wraps out...plus the fat end of the tie wraps acts as a grip to help pull them out.
Cheers...
nathbmx2005
« Reply #13 on: October 14, 2006, 05:44 PM »
when i worked at a motorbike shop the got the airline under the grip the blew it up like a balloon then it just pulled straight off
oldsky
« Reply #14 on: October 14, 2006, 07:53 PM »
Cheers...
Cant wait to try this one :daumenhoch:
« Reply #15 on: October 14, 2006, 08:07 PM »
i use clear plastic primer for mine in
spray the grips shake a bit then slide em on
