976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 04, 2026, 08:53 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  hollow stem bolts for newer 1 1/8 stems?
Author Topic: hollow stem bolts for newer 1 1/8 stems?  (Read 2789 times)
« on: December 05, 2006, 03:08 PM »
can you buy them anywhere?
cant find them at custom riders etc.... :'(
Offline Moose
Re: hollow stem bolts for newer 1 1/8 stems?
« Reply #1 on: December 05, 2006, 03:09 PM »
Usually Dia Compe do them, I'll have a butchers..........
« Reply #2 on: December 05, 2006, 03:09 PM »
fruity arnt they just the top nut.thats all u need.drill a hole in a blank one ..
Offline Moose
« Reply #3 on: December 05, 2006, 03:17 PM »
Billy's normally have them, but don't seem to be in stock now
http://www.billys.co.uk/english/productresults.php?dept=3460&group=I
Offline Moose
« Reply #4 on: December 05, 2006, 03:19 PM »
The Gusset one is in stock by the looks of things
« Reply #5 on: December 05, 2006, 04:11 PM »
ok,thanks phil. ill have a look.
dan, yeah its just a bolt, but mine has snapped..
« Reply #6 on: December 05, 2006, 04:13 PM »
u silly butch boy ,dont no your own strength   ;)
« Reply #7 on: December 05, 2006, 04:36 PM »
thats what you get when you try to stand on the handlebars at 14 1/2 stone.
« Reply #8 on: December 05, 2006, 04:37 PM »
reckon i might have fooked the headset too, as i had to ride from epic to the station, with the whole lot jangling about......
Vegan
« Reply #9 on: December 05, 2006, 04:41 PM »
I have a stem bolt that is brand new - i would need a replacement though, like for like condition
« Reply #10 on: December 05, 2006, 06:06 PM »
I'm a bit confused.......   Is it a new school clamp on stem?  If so, you can run quite happily without that centre bolt at all, its purely a headset tensioner. The stem then holds the whole thing together.  The bolt (if its only that) needs to match the forks...
Or am I way off?   :-[ :)
« Reply #11 on: December 06, 2006, 09:42 AM »
no, you were right TBR.
ive got one from billys now.
was running it for the rest of the evening snapped, but the stem seems to have worked its way loose, and jangled the bearings so, i reckon a new one is in order.
