976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 01, 2026, 03:53 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ************* ***** **** *** ** * GT Block/Malet stem
Author Topic: ************* ***** **** *** ** * GT Block/Malet stem  (Read 1729 times)
YGT
« on: December 06, 2006, 07:47 PM »
My latest ebay purchase of a GT white block stem seems to have gotten lost in the post.
So I need to paint my black GT Block stem instead.
Has anyone done this beofre or any tips?
Thanks
Mark
Re: ************* ***** **** *** ** * GT Block/Malet stem
« Reply #1 on: December 06, 2006, 07:48 PM »
mark i powder coat mine as paint scratches to easily
YGT
« Reply #2 on: December 06, 2006, 07:52 PM »
Hey Dan,
do you let them paint over the GT logo ? or do you sand it after coating.
Mark
« Reply #3 on: December 06, 2006, 07:55 PM »
i mask up any thing i want to keep unpainted unless its inverted inside the cast.
Offline jT Racing
  • i like bikes. :/
« Reply #4 on: December 07, 2006, 01:37 AM »
an alternative, is black heat resistant paint with heat resistant laquer over it. then when fully dry(24hrs) bake in oven at 160°C for an hour. rock hard and shiny. be sure to clean the paint off the logo first :daumenhoch:
ding dong
rakas17
« Reply #5 on: December 07, 2006, 11:11 AM »
heres one i painted, came out alright.  i used gloss 2pac white, didn't bother doin the detailed bits in different colours...
mark j
« Reply #6 on: December 10, 2006, 04:37 AM »
I had this one sprayed to match the frame, masked out the polished raised circle that the gt logo's in just a bit. Took the masking tape off  and to get rid the paint bleed got a small flat wood block with some fine sandpaper on.  Masked out the outside a bit incase I was a clumsy bugger and slowly went at it with the flat block. It came out perfect, really precise.
Joker808
« Reply #7 on: December 13, 2006, 01:57 AM »
I gotta go with the powder or paint. Powder will last a long time and you can sand it to reveal the GT logo.
If you do go with paint, make sure that you let it dry for a good long time before sanding the logo, I had to redo one that I didn't let sit and the paint gummed up the sandpaper.
