976303
crissy_criss
July 05, 2026, 03:42 AM
Tuff pads for V brakes
Topic: Tuff pads for V brakes (Read 2184 times)
karwash
December 12, 2006, 07:23 PM »
Are they available and if so where from.
Thanks.
Karwash
Moose
540 Air
Re: Tuff pads for V brakes
December 12, 2006, 07:38 PM »
Are you talking about the new skyway tuff pads? If you are, you should be able to get them from Alan's, Vert-ego or Ebay.com.
karwash
December 12, 2006, 07:59 PM »
Yeah I've seen those at Alans but they apear to be threaded with a bolt and washer setup rather than splined to be gripped by the clamp. Unless I'm being stupid, which is very possible
Moose
540 Air
December 12, 2006, 08:28 PM »
V brakes use threaded with nut and washer. U brakes use the other type.
stidds
Site Supporter
My life is Radbmx
Posts: I am a geek!!
December 12, 2006, 08:32 PM »
Not all V-Brakes use threaded Moose, I have a set of V-Brakes that use the spline shafts.
In answer to the question though, you will not be able to get Tuff Pads for the splined V-Brakes only threaded.
Moose
540 Air
December 12, 2006, 08:34 PM »
My apologies, I haven't come across ones that use splined pads yet.
Moose
540 Air
December 12, 2006, 08:36 PM »
...and I've just realised that some U brakes use threaded
Again, apologies for the duff information
karwash
December 12, 2006, 08:46 PM »
Thanks fella's thats put me on the right track
pickle
Site Supporter
My life is Radbmx
December 13, 2006, 10:13 AM »
I thought it was just Canti's that used the splined ones???
karwash
December 13, 2006, 11:07 PM »
It would appear not, the cheap and nasty one on the rear of the Haro I've just picked uses the splined type and so did the montain bikes I've had in the past. But then come to think of it they were cheap too.
