976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 01, 2026, 05:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Single pinch flight crank bolts?
Author Topic: Single pinch flight crank bolts?  (Read 2042 times)
Offline Nosnod
« on: December 13, 2006, 09:41 PM »
Did single pinch full wrap redline flight cranks always have the domed head allen bolt axle end bolts or did they ever come with hexagon bolts similar to Profile 2nd Gen?
And should there be small washers fitted on these bolts?
DR VINOAH
Re: Single pinch flight crank bolts?
« Reply #1 on: December 13, 2006, 09:50 PM »
scott
give bren a shout
im sure he has a decent scan
showing all hardware
Offline billstup
« Reply #2 on: December 13, 2006, 10:23 PM »
Dome type only I`m afraid, I bought a set of the chomed ones from Biagio and they look the bollocks, they are a bit hard to screw in for the first time though as the chrome makes them a little bit bigger, well they were very tight on a re-chromed set of flights, but they went in in the end  :daumenhoch:
Offline Nosnod
« Reply #3 on: December 14, 2006, 12:03 PM »
Cheers Billy I thought that was the case
Some clown from the US has sent me hex bolts with a BB set
Do they also have washers with them?
« Reply #4 on: December 14, 2006, 12:15 PM »
a twisted type washer (kinda split twisted  :daumenhoch:)
mark j
« Reply #5 on: December 14, 2006, 03:13 PM »
Called a spring washer....
I'm getting together the bits to make up complete new stainless hardware kits for 401 flights, will work out about £5 posted, all the correct washers, all that jazz. :)
« Reply #6 on: December 14, 2006, 03:16 PM »
Cool , I was only chatting with Phil (Sawzall) last night about these  :daumenhoch:
gmac
« Reply #7 on: December 14, 2006, 03:20 PM »
That'd be good Mark. I need the bolt that holds the c/w on
Offline Waxintaxin
« Reply #8 on: December 14, 2006, 03:45 PM »
Yea good idea , i need a set or 2
Rich
mark j
« Reply #9 on: December 14, 2006, 03:58 PM »
Good show boys, I've got most of the bits now just to suss out what's what and I'll get bigger quantities in now I'm happy with what I've got. They come from all different suppliers, because they're the old american threads you can't just get them in screfix. Need to get the right washers and we're sorted. Harley Davidson suppliers are good for bits but avoid hardware shops. Went to get 4 stainless allen bolts the other day for a hutch stem and they wanted £36!
Offline billstup
« Reply #10 on: December 14, 2006, 06:21 PM »
Yes its a complete set, have a look on this page : http://www.vert-ego.com/main.htm looks like they`re out of stock for the moment though  :(
The other thing I needed to do was cut down the bolt for holding on the chain wheel as it was too long  :daumenhoch:
mark j
« Reply #11 on: December 14, 2006, 09:35 PM »
I've got the correct stainless chainring bolts in, 3/4 inch ones, I'll sort something out over the next few days :daumenhoch:
