976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 10:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  info needed bb bearings
Author Topic: info needed bb bearings  (Read 3505 times)
« on: January 12, 2007, 03:42 PM »
i have an axle that is a tad bigger than my 19mm pofile bearings
has anyone else had any such bearings .mine seem to be 19.5mm
or is there an imperial size i should be asking for.
Offline Moose
Re: info needed bb bearings
« Reply #1 on: January 12, 2007, 04:06 PM »
I'm sure there's a 19mm/20mm axle (where the size of the axel increases where the bearings sit). Might have been Gusset or someone like that  ???
« Reply #2 on: January 12, 2007, 04:07 PM »
 ;D where ever did i put it   :idiot2: i thought it was there already cheers dordy   :4_17_5:
« Reply #3 on: January 12, 2007, 04:08 PM »
sounds about right moose
the bearing just wont seat so do they do 20mm bearings  never looked before
« Reply #4 on: January 12, 2007, 04:11 PM »
Quote
where ever did i put it    i thought it was there already cheers dordy
lol parks tracks and gatherings  ;D.
Offline Moose
« Reply #5 on: January 12, 2007, 04:11 PM »
« Last Edit: January 12, 2007, 04:13 PM by Moose »
« Reply #6 on: January 12, 2007, 04:14 PM »
 :daumenhoch: will give them a honk
unless any one out there has any .20mm bb bearings anybody for a sad old sod .
Offline BrianP
« Reply #7 on: January 12, 2007, 07:06 PM »
i've got some 20mm ID bearings Dan, they were in a Euro BB. I'll check out the OD of them.
(I got the 20mm axle turned down to 19mm on a lathe by a mate so I could run a profile US BB on it)
LMK what OD bearings you need mate (and gimme a shout re the standard stickies too)
Brian.
« Reply #8 on: January 12, 2007, 07:10 PM »
will do brian   :daumenhoch:
« Reply #9 on: January 12, 2007, 07:16 PM »
Yes the Spindle on my Haro Fusion Cranks, gets a bit bigger where the Bearings sit, what crank is it  ???
« Reply #10 on: January 12, 2007, 07:26 PM »
havent the foggiest got them of rad member few weeks back
Offline BrianP
« Reply #11 on: January 13, 2007, 04:16 PM »
Dan
I've four bearings here out of a Euro BB, 20mm ID, 31mm OD.
They'd hardly be big enough, would they?
Brian.
« Reply #12 on: January 13, 2007, 04:18 PM »
i will look tommorrow when i can have a look .i think the od is as profile and 20mm id
