976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 04, 2026, 06:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  us/mid bb
Author Topic: us/mid bb  (Read 2103 times)
rarman1
us/mid bb
« on: March 07, 2007, 12:14 AM »
sorry chaps but am i to belive that US/MID BB are the same
darkersomeday
Re: us/mid bb
« Reply #1 on: March 07, 2007, 01:13 AM »
yes sir,
the mid bottom bracket is designed to use profile 19mm axle sixed sized bearings without the alloy cups the would normally sit in the frame,
primo usa 22m axle sized bearings are a little bigger and wont fit in the mid bb,
what crank and bottom bracket do you have/intend to fit?
rarman1
Re: us/mid bb
« Reply #2 on: March 07, 2007, 07:39 PM »
bugger got a new sunday frame from winstanleys, already own primo powerbites, am i stuffed
Re: us/mid bb
« Reply #3 on: March 07, 2007, 07:44 PM »
if you go to a bearing supplies ,tell them the bb size and your axle size then they might match them.
rarman1
Re: us/mid bb
« Reply #4 on: March 07, 2007, 07:50 PM »
that sounds good as i really like my powerbites, do you know of a bearing shop in london dan ?
Re: us/mid bb
« Reply #5 on: March 07, 2007, 07:52 PM »
im in suffolk i use a local company called thetford bearing supplies
so you should easily find one in the book mate.
rarman1
Re: us/mid bb
« Reply #6 on: March 07, 2007, 08:30 PM »
iv'e just seen that odyssey do a mid bb for 22mm cranks sorted then ;)
Re: us/mid bb
« Reply #7 on: March 07, 2007, 08:33 PM »
