976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 05, 2026, 04:04 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing knackered allen bolts
Author Topic: Removing knackered allen bolts  (Read 1515 times)
the stag
« on: March 16, 2007, 04:36 PM »
…rescued another bike from the tip today – anyone got any ideas how to remove an allen bolt from the stem, that has worn away inside and the key is just spinning in there?
Thanks for your help
Offline kdw712
Re: Removing knackered allen bolts
« Reply #1 on: March 16, 2007, 04:44 PM »
If you can get a dremel in there what about grinding out a slot to get a flat blade screwdriver into
or grind awway the entire bolt head  - i had to do that with XCii and the hex head cage bolts
cheers Kev
the stag
« Reply #2 on: March 16, 2007, 04:47 PM »
i like the slot idea - good thinking - will give it a bash when i get home - thanks very much :daumenhoch:
Offline kdw712
« Reply #3 on: March 16, 2007, 04:48 PM »
can't beat grinding a nice slot  >:D  :daumenhoch:
cheers Kev
« Reply #4 on: March 16, 2007, 04:51 PM »
get a slightly larger splined bit and whack that in
« Reply #5 on: March 16, 2007, 04:51 PM »
the spline tool for undoing vw drive shafts is just a whisker over 6mm.
get one of them!
sonic-1
« Reply #6 on: March 16, 2007, 04:54 PM »
i to use spline drive hamered into the wrecked allen head
