976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 10:19 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dia Comp front brake
Author Topic: Dia Comp front brake  (Read 2508 times)
davidben
« on: April 23, 2007, 10:10 PM »
I have tried to fit a Dia Comp Nippon front brake, but the quick release bit
dosen't hold the cable, any ideas or help will be great.
The back brake is fine but the front has a different bit.
The photo show the quick release system and the whole wher the cable threads through
but how does it stay there or create a tension?
adeshere
Re: Dia Comp front brake
« Reply #1 on: April 23, 2007, 10:17 PM »
It should would like the rear.
Are you trying to use it on the front with a pots mod ?
davidben
« Reply #2 on: April 23, 2007, 10:20 PM »
I'm new to dia compe's the back looks like this, but the front is different
Offline Rombloke
  • do one
« Reply #3 on: April 23, 2007, 10:23 PM »
thats because the one you have is a potts mod, designed for your cable to be threaded thru your stem bolt, through the steerer tube, and up from the bottom of the brake not the top
Dave
haro, how do you do
adeshere
« Reply #4 on: April 23, 2007, 10:24 PM »
You beat me too it
davidben
« Reply #5 on: April 23, 2007, 10:28 PM »
Oh, so it the reverse of the back brake, have you got pictures of how I should set it up.
I just got the brake lever out and that is different as well.
Sorry for being thick, but never seen these before
 :shocked:
adeshere
« Reply #6 on: April 23, 2007, 10:36 PM »
Not normal for the brake lever to be different.
The pots mod, is where you have a hollow stem bolt, so you can pass the front brake cable down through the stem and through the forks, so th ecable comes out where the brake bolt goes through.
You then loop the brake cable back upwards and connect it to the brake.
This is used for freestyle, so you can spin the bars round and round with out the cable getting tied up.
Here is my TA with one
davidben
« Reply #7 on: April 23, 2007, 10:59 PM »
Nice bike,
Can the brake still work on a non-freestyler.
How do you get the cable up to the lever?
 :shocked:
« Reply #8 on: April 24, 2007, 08:40 AM »
You have to have a hollow stem bolt (if you haven't you can get ACS ones for about a tenna) then the cable goes down that, out of the forks then loops round and goes into the bottom of the brake rather than the top.  The cable should then just fit into the lever like normal.    :daumenhoch:
davidben
« Reply #9 on: April 25, 2007, 10:14 PM »
Can you let me know where I can get one from, been on alansbmx.com, but see one.
 :uglystupid2:
Actually just found this
https://www.extreme-direct.co.uk/bmx/stems/ruption/23852.php
but I will still need to cut the end of the cable off to thread it through the brake, but how does it then connect to the
brake lever when the end is missing?
I have never come across this style of brake before, anyone got a step by step guide.
Losing sleep over it
« Last Edit: April 25, 2007, 10:55 PM by davidben »
« Reply #10 on: April 26, 2007, 04:51 AM »
What stem are you running?
davidben
« Reply #11 on: April 26, 2007, 07:37 AM »
« Reply #12 on: April 26, 2007, 08:12 AM »
that stem already has a potts mod.
« Reply #13 on: April 26, 2007, 08:13 AM »
« Reply #14 on: April 26, 2007, 03:48 PM »
The stem has a hole in the bolt that will take both the inner and outer cable. All you do is thread it through there and attach it to the bottom of the caliper. If there is nothing on the fork to hold the cable away from the wheel use a cable tie or two.
