976243 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 04:02 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Can you dye brake cable outers?, i want to change colour.
Author Topic: Can you dye brake cable outers?, i want to change colour.  (Read 3112 times)
2020mad
Hi i have a skyway spinmaster set-up with white cables. i want to change these to black will they dye ? or does any one know how i could do this without them looking crap as i can't get black cables for this. thanks.
Re: Can you dye brake cable outers?, i want to change colour.
« Reply #1 on: June 28, 2007, 12:58 PM »
no.....don't be so bloomin stupid
wouldn't of thought so though mate  :-\
« Reply #2 on: June 28, 2007, 01:00 PM »
only nylon will dye.
plastic and rubber doesnt go so well.
get some coloured shrink wrap.
2020mad
« Reply #3 on: June 28, 2007, 01:02 PM »
 :( really need them to be black, white cables will fook my MK build right up, I may try spraying with plasticote paint :-\
2020mad
« Reply #4 on: June 28, 2007, 01:03 PM »
  coloured shrink wrap would do. any idea where to start looking . maplins?, b&q ?
« Reply #5 on: June 28, 2007, 01:04 PM »
i'd leave em mate.......i'm sure white cables won't make that much of a diference  :-\
what's it on?  your Street Beat?
« Reply #6 on: June 28, 2007, 01:05 PM »
Wasn't Maplins the holiday camp for Hidehi?  i'm sure it's shut now.....
2020mad
« Reply #7 on: June 28, 2007, 01:17 PM »
                        yep bought another beat monday eve, my other beat won't be ready for MK so am building something a bit different to bring along, white cables will not go unfortunatly, may have to fit a spinmaster2 instead. :'(
« Reply #8 on: June 28, 2007, 01:19 PM »
maplins used to sell it. how long do you need it? the car shop near me sells black, i thought you'd want a fancy colour....
2020mad
« Reply #9 on: June 28, 2007, 01:22 PM »
no just black, will have a look at some car accessory shops by me.  cheers phil. :daumenhoch:
« Reply #10 on: June 28, 2007, 01:30 PM »
If it's just black outer cable you want then Tesco sell them.....well the big one near me does  :-\
£2.50 i think with all the bits!
2020mad
« Reply #11 on: June 28, 2007, 02:09 PM »
                                          the spinmaster giro has loads of short cables with funny non standard shape ends on both ends of the cables to make it work, it will probley be cack and won't work when i fit it anyway.
Trev
« Reply #12 on: June 28, 2007, 02:31 PM »
Buy a black permanant marker...
2020mad
« Reply #13 on: June 28, 2007, 02:33 PM »
               already considered that  :LolLolLolLol:
Offline BrianP
« Reply #14 on: June 29, 2007, 11:19 PM »
you want a cheaper version of this stuff, 2020:
http://www.polymarine.com/products/parts-and-accessories/flexible-paints-and-antifoulings/superflex-pvc-paint/black-superflex-[1768].cfm
or maybe even this stuff?
http://a1autowise.com/GLOSSBLACKL100.aspx (holts paint supposedly also compatible with plastics...)
Bp.
crazy foool
« Reply #15 on: July 01, 2007, 11:08 AM »
are spin masters the detanglers that have one cable going through the top of your stem body, into the spinny bit and two coming out, if so i need one and where can i get one from?
gt0733
« Reply #16 on: July 01, 2007, 11:41 PM »
in my neck of the woods black cables fall from the trees. white ones left the building with the dodos  :shocked: there is no way i would dye a white cable just in case i needed it for a future build.
