976243 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 07:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stem bolt
Author Topic: stem bolt  (Read 3238 times)
Offline priv
stem bolt
« on: July 07, 2007, 03:33 AM »
having never run a front brake and now i've got one what's with the stem bolt that can have a cable running through it?.is it a certain type of stem that has them?
cheers..priv
ps i've got a profile hip on at the moment
Re: stem bolt
« Reply #1 on: July 07, 2007, 06:39 AM »
i'm presuming it's a new school stem you've got there??  all you need mate is one of these type of bolts....
http://www.chainreactioncycles.com/Models.aspx'modelID=18603
Re: stem bolt
« Reply #3 on: July 07, 2007, 06:41 AM »
Great minds eh pickle, and within seconds  :LolLolLolLol:
Offline priv
Re: stem bolt
« Reply #4 on: July 07, 2007, 06:31 PM »
Thanks men,now  i need somemore advice,i've fitted a star nut on a mtb and it was a right pain getting it in straight,any tips on getting it in straight?
cheers.again..priv
Offline Dingobmxer
Re: stem bolt
« Reply #5 on: July 07, 2007, 07:47 PM »
use the proper tool Adey  :LolLolLolLol:
 :) DINGO :)
Offline priv
Re: stem bolt
« Reply #6 on: July 07, 2007, 08:21 PM »
 :) DINGO :)
thanks mate,but is that proper as in correct or as in trev trying to sell me a "proper" tool,like his proper barends?
i'll have a look next week and decide if i can be ar*ed to do it at all :2funny:
Offline Dingobmxer
Re: stem bolt
« Reply #7 on: July 07, 2007, 08:43 PM »
Proper as in correct mate
but you can get them in square with a bit of care
 :) DINGO :)
THIRSTYKIRSTY
Re: stem bolt
« Reply #8 on: July 08, 2007, 06:41 AM »
PRIV MY MAN
I USE A LONG SOCKET THAT WOILL FIT ON NICE AND 1 HARD FIRM BANG DOES IT
WELL IT WORKED FOR ME
IM ALSO KNOWN AS A ROUGH ARSE :-\ :-\ :-\
RUSS
Trev
Re: stem bolt
« Reply #9 on: July 08, 2007, 08:28 AM »
 :) DINGO :)
did someone say bar ends?  ::)
Re: stem bolt
« Reply #10 on: July 08, 2007, 09:32 AM »
Priv......if you take the stem off you may find the forks have the threaded bit welded in them already....if not the way i've allways installed them on my MTBs is to screw the stem bolt into the nut (this gives you something to hit and to line it up with) then it's just a case of lining it up and a good hit with the irish screwdriver   :daumenhoch:
