976314 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 23, 2026, 12:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  redline proline cranks
Author Topic: redline proline cranks  (Read 8925 times)
rarman1
« on: August 10, 2007, 07:53 PM »
hi all,
i've got some redline proline cranks but they came with euro bb, i've seen on alans they do a sealed us bb kit for 20mm spindle,
does anyone know if this will fit properly ?
thanks,
rob
Offline billstup
Re: redline proline cranks
« Reply #1 on: August 10, 2007, 09:11 PM »
I think the redline spindles are 19mm  :(
Offline Rombloke
  • do one
« Reply #2 on: August 11, 2007, 12:44 PM »
not the prolines bill they are larger than 19mm, the flight II's however are a 19mm.
Dave
haro, how do you do
rarman1
« Reply #3 on: August 11, 2007, 12:50 PM »
yeah i tried a 19mm from my profiles but they were too small,
but would this fit them ?
 http://www.alansbmx.com/product_info.php?cPath=32_35&products_id=2106&osCsid=80006ae01121e54b5bdd7bf90b72cde5
or does anybody have details for where i can get redline bb as i'm having no luck on the net,
cheers,
rob
HEYWOOD BMX
« Reply #4 on: August 11, 2007, 01:02 PM »
 :) I have a Redline Proline crank and B/B in bits next to me and they are 19mm.
                  James
HEYWOOD BMX
« Reply #5 on: August 11, 2007, 01:11 PM »
 :) Checked and my Prolines fit in a DK Chopstix Euro B/B,which I am sure is 19mm.?????
rarman1
« Reply #6 on: August 11, 2007, 01:50 PM »
just read up on dk's site and chopstix do have a 19mm spindle, but then so does profile and my profile bb does not fit !!
what size spindle do flights have ?
maybe i need one of those measure thingy's  :-\
« Reply #7 on: August 11, 2007, 05:14 PM »
Both my sets of Flights have different size axles so I'm no help on the measurements however, Aldi do a digital vernier caliper for about £8  :daumenhoch:
bof
« Reply #8 on: August 11, 2007, 07:21 PM »
I could be wrong here but is the spindle raised after the splines, if so then i would imagine it is a 20mm spindle . :)
Offline Rombloke
  • do one
« Reply #9 on: August 11, 2007, 10:44 PM »
prolines are 20mm deffo.....
Dave
haro, how do you do
gt0733
« Reply #10 on: August 11, 2007, 11:08 PM »
i think i'm in the same boat.
my set of early 90's flites have a non sealed BB, the problem i have is the chainwheel spacer has an inside diameter smaller than the spindle diameter. so i'm thinking i may have the 20mm spindle.
what i don't know is do all crank arms have the same size splines so all i need to do is get a nice sealed BB and put my cranks on them?
to be honest i'm tired of pulling the flites off and putting the one piece in just to go for a ride  :-[
« Reply #11 on: August 12, 2007, 11:56 AM »
Dave
You'd better get on to Redline and let them know...
http://www.redlinebicycles.com/parts/cranks-proline.html
 :D :P ;)
Also, the flight cranks with the floating spindle on a sealed bottom bracket some times came with a very thin top hat washer, I think this reduced the internal size of the bearing from imperial to metric ( or the other way around)...  not sure on the dates though ???
« Last Edit: August 12, 2007, 12:01 PM by Ron Burgundy »
« Reply #12 on: August 12, 2007, 05:10 PM »
Dave
That's what one set of mine has, a very thin top hat style washer  :daumenhoch:
rarman1
« Reply #13 on: August 12, 2007, 06:46 PM »
Dave
yep me too on my single pinch non full wrap flights,
yeah mine are raised after the splines too,
thanks chaps  :4_17_5:
i'm gonna go for the 20mm sealed bearing kit :daumenhoch:
« Reply #14 on: August 12, 2007, 06:56 PM »
bof
« Reply #15 on: August 12, 2007, 07:15 PM »
Custom riders also do these if the 20 mm is too big, which is nice.
http://www.customriders.com/prodshow.asp?prodid=7313&cat=10&parent=1001&sid=3
Offline Rombloke
  • do one
« Reply #16 on: August 12, 2007, 07:23 PM »
im deffo gonna contact redline cos these proline cranks aint 19mm.
cranks and 19mm a/f spanner
19mm spanner
ok the spanner fits over the splines...so i guess they are 19mm.
but where the bearing sits the spanner does not fit over.....so i was right
redline prolines do take a 20mm bearing....
Dave
haro, how do you do
« Reply #17 on: August 12, 2007, 07:31 PM »
my twin pinch flghts are the same deal, 19 at the spline then 20 at the bearing point
rarman1
« Reply #18 on: August 12, 2007, 07:54 PM »
rarman1
« Reply #19 on: August 14, 2007, 02:03 PM »
just got the D20 sealed BB kit from alans and its a perfect fit everybody :daumenhoch:
