976254 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 13, 2026, 08:01 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  10mm drop-outs to 14mm
Author Topic: 10mm drop-outs to 14mm  (Read 1625 times)
spesh
« on: August 15, 2007, 07:31 PM »
i have some hoffman forks coming that have 10mm drop-outs,can they be re-drilled to 14mm
is it hard to do or could any machine shop do it?
or am i better off getting new forks?
dj_benice
Re: 10mm drop-outs to 14mm
« Reply #1 on: August 15, 2007, 07:47 PM »
shouldn't be all that difficult, depends if there is enough meat on the dropouts though as to whether they will be strong enough, decent pillar drill should do it  :daumenhoch:
« Reply #2 on: August 15, 2007, 08:09 PM »
just get a 14 mm axle that is flat ie 10 mm
Offline BrianP
« Reply #3 on: August 15, 2007, 08:51 PM »
yep, definitely enough meat on these forks, (about 6mm thick) they'll be spot on after being cut.
Brian.
spesh
« Reply #4 on: August 15, 2007, 11:19 PM »
did you get my payment brian?
cheers dave
darkersomeday
« Reply #5 on: August 16, 2007, 07:22 AM »
just be really careful when you cut :daumenhoch:
mark twice and cut once, remember if you get it even a millimetre out it'll translate to alot more at the top of the wheel, leaving your front wheel constantly out of alignment!
if possible try not to touch the top inside of the slot where the axle actually rests, just open the sides enough :daumenhoch:
Offline BrianP
« Reply #6 on: August 16, 2007, 08:48 AM »
cheers dave
Did indeed mate, many thanks!
(Trying to find a big cardboard box in work at the mo!)
Speak to you soon,
Brian  :daumenhoch:
