976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 03:06 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  square taper cranks/bottom bracket
Author Topic: square taper cranks/bottom bracket  (Read 2093 times)
thesku11s
« on: October 29, 2007, 11:01 PM »
this has always been a bit of a grey are for me:
Is it possible to run a normal square taper crank from a mtb/road bike in a bmx frame with U.S sized BB shell?
Basically would the standard mtb spindle, work with a standard loose ball bmx bottom bracket set ?
I always thought the spindles were different, but this guy in a bike shop told me they were exactly the same.
I havent had a chance to try it out, but can anyone clear this up?
Re: square taper cranks/bottom bracket
« Reply #1 on: October 29, 2007, 11:03 PM »
try it!
you'd think they were the same, once the US shit is screwed onto them
Offline Philbert
« Reply #2 on: October 29, 2007, 11:11 PM »
i'll look into that. i'll have a play at work with some old stuff thats lying around.
personally i'll be really surprised if it does work, surely if it did work people would have been doing it for years
« Reply #3 on: October 29, 2007, 11:16 PM »
im running a sealed bottom bracket in me boys turbolite of a mountain bike so yes works if its euro bb
thesku11s
« Reply #4 on: October 30, 2007, 12:19 AM »
obviously that would work!
Im trying to find out if a spindle from a euro bb setup is compatible with a us bb setup...
I cant see how it would work personally, but this old guy normally knows his stuff.
« Reply #5 on: October 30, 2007, 08:53 AM »
so long as the us bearing fit the axle then yes it will work
Offline Waxintaxin
« Reply #6 on: October 30, 2007, 06:46 PM »
it depends
the key to this is the axle size and the bearing size
not all axles are the same size , and neither are the bearings
so if you got non standard or rather didnt come with the cranks bearings, you should be able , if they make that size bearing ,get any spindle in any BB cup Euro or USA
it makes sense to me anyway
bof
« Reply #7 on: November 01, 2007, 03:10 PM »
DMR wondercups enable you to use a euro BB in a US BB frame  :) thus enabling you to use MTB cranks. :daumenhoch:
« Reply #8 on: November 01, 2007, 04:43 PM »
wot he said :daumenhoch:
