976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 06:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  RIM HELP
Author Topic: RIM HELP  (Read 1680 times)
insideoutland
RIM HELP
« on: November 18, 2007, 11:11 AM »
JUST PICKED THESE UP  SER2 SER3 PRO CLASS  :), JUST WANTED TO KNOW IF THE SER3 CAN BE CLEANED UP TO MATCH  SER2 , :-\
I.E OVEN CLANER WET&DRY  :daumenhoch: ANY HELP WILL BE  ;)  CHEERS PHIL
« Last Edit: November 18, 2007, 11:13 AM by insideoutland »
Re: RIM HELP
« Reply #1 on: November 18, 2007, 11:44 AM »
The dark rim is a hard anodised rim, not sure if it can be stripped in the same way, maybe Login_user or Atari_Ager can help as they are both Mongoose men  :daumenhoch:
login_user
Re: RIM HELP
« Reply #2 on: November 18, 2007, 01:08 PM »
Pm sent  Mate, it can be stripped but it,will be harder then normal.  :daumenhoch:
etriedes
Re: RIM HELP
« Reply #3 on: November 18, 2007, 11:52 PM »
Caustic Soda, Thick Rubber Gloves, Mask, Eye Protection, and well ventilated area will do it  ;)
insideoutland
Re: RIM HELP
« Reply #4 on: November 19, 2007, 12:28 AM »
AND AFTER THE C SODA  :D WILL THEY BE GOOD FOR A GOOD BUFF WITH SOME AUTO SOL?? :shocked:
Offline sawzall
Re: RIM HELP
« Reply #5 on: November 21, 2007, 06:56 PM »
i did these which were hard anno pc3s, i stripped the anno using caustic which took ages to do,i just kept checking them to make sure they had'nt dissapeared then mirror polished them
insideoutland
Re: RIM HELP
« Reply #6 on: November 22, 2007, 08:57 AM »
they look spot on dude :shocked: did you do the polish your self ?what best to use???
Offline sawzall
Re: RIM HELP
« Reply #7 on: November 22, 2007, 06:45 PM »
yes mate i used a bench polishing mop,i use three stage polishing,from cource cutting compound,then medium and finish off with fine,they take a long time to do because of all the holes and you have to be careful not to loose any of the definition of the spoke holes etc ;)
insideoutland
Re: RIM HELP
« Reply #8 on: November 22, 2007, 10:31 PM »
cheers  :4_17_5:
