976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 06:36 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Basic stuff, question 1 - coaster brake
Author Topic: Basic stuff, question 1 - coaster brake  (Read 1815 times)
nhoj
« on: March 07, 2008, 07:33 PM »
What does a coaster brake actually do? BITD I thought it let you do a roll-back without peddling backwards, is that right, is that all it does? :-\
P.S.  Never really thought about it much in the last twenty odd years untill some new skyways arrived from ebay today with a coaster fitted :D
Re: Basic stuff, question 1 - coaster brake
« Reply #1 on: March 07, 2008, 08:03 PM »
its ya rear brake
nhoj
« Reply #2 on: March 07, 2008, 08:07 PM »
In leymans terms - a pedal backwards brake? :-\
« Reply #3 on: March 07, 2008, 08:07 PM »
Yeah, you do roll back without pedalling as long as you 'set' the coaster first.  To do this, you crank backwards a tiny bit. Dont do this and you'll pedal backwards as normal.
Crank backwards a little harder and you'll apply the brake. This is true whether you're going forwards or backwards.
A coaster hub isn't a ratchet like a freewheel is, the insides are completely different.   :)
Offline Rombloke
  • do one
« Reply #4 on: March 08, 2008, 10:25 AM »
well explained i feel mr steele.
1 merit mark for you dear boy
Dave
haro, how do you do
« Reply #5 on: March 10, 2008, 09:38 PM »
Ayethankyou   ;D
Offline aerostylie
« Reply #6 on: March 10, 2008, 11:00 PM »
And whats the thing with the seat clamp acting as/with a coaster, never quite understood that/how it works ???
Paul
Vans Style
« Reply #7 on: March 10, 2008, 11:08 PM »
The coaster has to be anchored to a fixed point if you want the brake to work. If the frame didn't have a coaster bracket then the done thing was to use a seatclamp to anchor the coaster arm to the frame   :)
Offline aerostylie
« Reply #8 on: March 10, 2008, 11:17 PM »
Arrrrr I see, what a cool idea, any idea who came up with that?
Also thanx Rob for the answer, you da man 8)
Vans Style
