976297 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 10:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  crank trouble still
Author Topic: crank trouble still  (Read 1395 times)
eloopnai
crank trouble still
« on: April 03, 2008, 05:35 PM »
posted on here ages ago about the crank not beeing even in the bottom bracket on my supergoose 3
ive now got 2 other cranks and the same happens
on my other goose a 81 the middle section of the crank is shorter which is what i need for this one i presume ?
but i thought there was only one size crank for bmx bikes ? just the arm length differed ?
ive got some redline 3 piece cranks on there way soon will these fit i hope so the money they cost  :LolLolLolLol:
ive put a spacer washer in but its still not enough is there somin wrong with my bike ?
im totally confused hope someone could help me please  :D
Offline Rombloke
  • do one
Re: crank trouble still
« Reply #1 on: April 03, 2008, 06:06 PM »
unfortunatley one piece cranks are 'set'
so what you need to do is maybe put an extra washer between the chain ring/spider and the drive side bearing race, thus pulling the cranks 'through' the bb by the thickness of the washer.
make sense?
Dave
haro, how do you do
eloopnai
« Reply #2 on: April 03, 2008, 06:35 PM »
cheers will try that  :daumenhoch:
eloopnai
« Reply #3 on: April 03, 2008, 07:07 PM »
ok with some washers in its levalled it up now ive fooking forgot what way round the bearings sit balls into the cups or away from the cups  :LolLolLolLol:
jackel
« Reply #4 on: April 03, 2008, 07:31 PM »
balls into cups learnt this the hard way back in the day :)
eloopnai
« Reply #5 on: April 03, 2008, 09:38 PM »
cheers :)
eloopnai
« Reply #6 on: April 05, 2008, 09:36 AM »
now im more confused then the other day postman just delivered a takagi cro mo 24tpi one piece crank its a different size to the others ive got the middle part is shorter so will fit perfectly without a huge spacer ( or rather  part of a headset  :LolLolLolLol: )
so there defo is 2 different size one piece cranks
 :D  :D  :D
Offline Gary72
« Reply #7 on: April 05, 2008, 09:42 AM »
I think some BB shells are different widths, and some 3 piece cranks come with 2 spacer tubes for this reason, no idea what frame makers had what size's though.
eloopnai
« Reply #8 on: April 05, 2008, 09:53 AM »
cheers for that gary confirms what i was thinking  :daumenhoch:
thought i had a moody bike for a minute
just hoping the redline flites that are on there way fit although im sure i could get a shorter spindle if needed
more fun and games when they arrive
